I have had my GL-MT6000 setup for around 3 weeks now and was able to access the Admin Panel with no issue. After a reboot today I can no longer access the Admin Panel. But I can access with the same password on /cgi-bin/luci/admin/status/overview. I can also SSH into the router with the same password as before, any way to reset the Admin Panel password after SSH into the router so that I don't have to factory reset?
This destroys the GL GUI. Please don't upgrade plugins. Never, ever.
Unfortunately, you might need to reset your device now because the GL GUI is broken.
This worked, I flashed the firmware from the download and was able to keep the current settings. It let me sign back into the GL GUI with the root password.
@admon - hijacking this post and wanted to ask what "destroys the GL GUI" and why is it possible to upgrade plugins if this is known to break it?
i too havent updated plugins but i had the same message as @jordfoz16 where i couldnt access the router log in with password, however could with Luci.
had to factory restore the device and restore my configuration.
just a thought: is it possible to set the reset button on the back of the MT6000 to have certain functionality? rather than hold 10s to reset device, is it possible to have it so that you can hold 5s to reset password as well as hold 10s for reset device?
You need to understand the OpenWrt is a real operating system running a few processes to act like a router. If you upgrade some parts (or install plugins that overwrites stuff) it could break the main functionality.
The GL GUI is just some more or less fancy website, not a real application itself. This complex ecosystem provided the known feature-sets of the GL devices.
If you upgrade packages, they can remove functionalities needed - which can cause issues. Same for upgrades in lua which is used as the main programming language on the device spoken for GL components.
Because OpenWrt (and GL) is about freedom.
Freedom of break things is included as well
