GL-MT6000 after scheduled restart it not start wifi
Fri Jan 12 04:00:35 2024 user.notice AdGuardHome[6286]: 2024/01/12 03:00:35.356605 [info] Initializing auth module: /etc/AdGuardHome/data/sessions.db
Fri Jan 12 04:00:35 2024 user.notice AdGuardHome[6286]: 2024/01/12 03:00:35.356993 [info] auth: initialized. users:0 sessions:0
Fri Jan 12 04:00:35 2024 user.notice AdGuardHome[6286]: 2024/01/12 03:00:35.357064 [info] web: initializing
Fri Jan 12 04:00:35 2024 user.notice ddns-scripts[6715]: glddns: PID ‘6715’ started at 2024-01-12 04:00
Fri Jan 12 04:00:35 2024 daemon.info dnsmasq[1]: started, version 2.89 cachesize 1000
Fri Jan 12 04:00:35 2024 daemon.info dnsmasq[1]: DNS service limited to local subnets
Fri Jan 12 04:00:35 2024 daemon.info dnsmasq[1]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset nftset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Fri Jan 12 04:00:35 2024 daemon.info dnsmasq[1]: UBus support enabled: connected to system bus
Fri Jan 12 04:00:35 2024 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 192.168.15.2 – 192.168.15.249, lease time 12h
Fri Jan 12 04:00:35 2024 daemon.info dnsmasq[1]: using nameserver 127.0.0.1#3053
Fri Jan 12 04:00:35 2024 daemon.info dnsmasq[1]: using only locally-known addresses for test
Fri Jan 12 04:00:35 2024 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Fri Jan 12 04:00:35 2024 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Fri Jan 12 04:00:35 2024 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Fri Jan 12 04:00:35 2024 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Fri Jan 12 04:00:35 2024 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Fri Jan 12 04:00:35 2024 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Fri Jan 12 04:00:35 2024 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 6 names
Fri Jan 12 04:00:35 2024 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Fri Jan 12 04:00:35 2024 kern.info kernel: [ 22.356310] mt7530-mdio mdio-bus:1f lan5: Link is Up - 100Mbps/Full - flow control rx/tx
Fri Jan 12 04:00:36 2024 kern.info kernel: [ 22.448367] br-lan: port 5(lan5) entered blocking state
Fri Jan 12 04:00:36 2024 kern.info kernel: [ 22.453609] br-lan: port 5(lan5) entered forwarding state
Fri Jan 12 04:00:36 2024 daemon.notice netifd: Network device ‘lan5’ link is up
Fri Jan 12 04:00:36 2024 user.notice AdGuardHome[6286]: 2024/01/12 03:00:36.372832 [info] dnsproxy: cache: enabled, size 4096 b
Fri Jan 12 04:00:36 2024 user.notice AdGuardHome[6286]: 2024/01/12 03:00:36.372909 [info] MaxGoroutines is set to 300
Fri Jan 12 04:00:36 2024 user.notice AdGuardHome[6286]: 2024/01/12 03:00:36.470261 [info] AdGuard Home is available at the following addresses:
Fri Jan 12 04:00:36 2024 user.notice AdGuardHome[6286]: 2024/01/12 03:00:36.472014 [info] go to http://127.0.0.1:3000
Fri Jan 12 04:00:36 2024 user.notice AdGuardHome[6286]: 2024/01/12 03:00:36.472114 [info] go to http://[::1]:3000
Fri Jan 12 04:00:36 2024 user.notice AdGuardHome[6286]: 2024/01/12 03:00:36.472138 [info] go to http://[fe80::182a:60ff:febd:874a%eth0]:3000
Fri Jan 12 04:00:36 2024 user.notice AdGuardHome[6286]: 2024/01/12 03:00:36.472158 [info] go to http://[fe80::9683:c4ff:fea7:8d6%eth1]:3000
Fri Jan 12 04:00:36 2024 user.notice AdGuardHome[6286]: 2024/01/12 03:00:36.472177 [info] go to http://192.168.15.1:3000
Fri Jan 12 04:00:36 2024 user.notice AdGuardHome[6286]: 2024/01/12 03:00:36.472198 [info] go to http://[fd50:a2f6:12af::1]:3000
Fri Jan 12 04:00:36 2024 user.notice AdGuardHome[6286]: 2024/01/12 03:00:36.472215 [info] go to http://[fe80::9683:c4ff:fea7:8d8%br-lan]:3000
Fri Jan 12 04:00:36 2024 user.notice AdGuardHome[6286]: 2024/01/12 03:00:36.472232 [info] go to http://10.0.0.1:3000
Fri Jan 12 04:00:36 2024 user.notice AdGuardHome[6286]: 2024/01/12 03:00:36.472249 [info] go to http://[fd00:db8:0:abc::1]:3000
Fri Jan 12 04:00:37 2024 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) 192.168.15.249 94:83:c4:24:13:02
Fri Jan 12 04:00:37 2024 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.15.249 94:83:c4:24:13:02
Fri Jan 12 04:00:37 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.15.10 94:83:c4:34:4f:f8
Fri Jan 12 04:00:37 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.15.10 94:83:c4:34:4f:f8 GL-SFT1200
Fri Jan 12 04:00:37 2024 daemon.notice netifd: wan (4571): udhcpc: broadcasting discover
Fri Jan 12 04:00:37 2024 daemon.notice netifd: wan (4571): udhcpc: broadcasting select for 51.174.118.122, server 79.160.116.236
Fri Jan 12 04:00:38 2024 daemon.notice netifd: wan (4571): udhcpc: lease of 51.174.118.122 obtained from 79.160.116.236, lease time 23578
Fri Jan 12 04:00:38 2024 daemon.info avahi-daemon[4158]: Joining mDNS multicast group on interface eth1.IPv4 with address 51.174.118.122.
Fri Jan 12 04:00:38 2024 daemon.info avahi-daemon[4158]: New relevant interface eth1.IPv4 for mDNS.
Fri Jan 12 04:00:38 2024 daemon.info avahi-daemon[4158]: Registering new address record for 51.174.118.122 on eth1.IPv4.
Fri Jan 12 04:00:38 2024 daemon.notice netifd: Interface ‘wan’ is now up
Fri Jan 12 04:00:38 2024 user.notice firewall: Reloading firewall due to ifup of wan (eth1)
Fri Jan 12 04:00:38 2024 user.notice ddns-scripts[5658]: glddns: PID ‘5658’ terminated by ‘SIGTERM’ at 2024-01-12 04:00
Fri Jan 12 04:00:39 2024 authpriv.notice sudo: root : PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/ddns/dynamic_dns_updater.sh – stop
Fri Jan 12 04:00:39 2024 kern.warn kernel: [ 25.471452] HTB: quantum of class 10001 is big. Consider r2q change.
Fri Jan 12 04:00:39 2024 kern.warn kernel: [ 25.494273] HTB: quantum of class 10001 is big. Consider r2q change.
Fri Jan 12 04:00:39 2024 daemon.info gl-cloud[7520]: (gl-cloud:685) lua-eco version: 3.2.0
Fri Jan 12 04:00:39 2024 daemon.info gl-cloud[7520]: (gl-cloud:164) fetch ca from: https://gslb-eu.goodcloud.xyz/getCaCert/ca.crt
Fri Jan 12 04:00:39 2024 kern.warn kernel: [ 26.108319] HTB: quantum of class 10001 is big. Consider r2q change.
Fri Jan 12 04:00:39 2024 kern.warn kernel: [ 26.308421] HTB: quantum of class 10001 is big. Consider r2q change.
Fri Jan 12 04:00:40 2024 daemon.notice procd: /etc/rc.d/S99gl_eqos: RTNETLINK answers: Invalid argument
Fri Jan 12 04:00:40 2024 daemon.notice procd: /etc/rc.d/S99gl_eqos: We have an error talking to the kernel
Fri Jan 12 04:00:40 2024 authpriv.notice sudo: root : PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/ddns/dynamic_dns_updater.sh – start
Fri Jan 12 04:00:40 2024 daemon.notice procd: /etc/rc.d/S99gl_nas_sys_dl: start app = /usr/bin/gl_nas_sys
Fri Jan 12 04:00:40 2024 daemon.notice procd: /etc/rc.d/S99gl_nas_sys_dl: === nas enable
Fri Jan 12 04:00:40 2024 daemon.notice procd: /etc/rc.d/S99gl_nas_sys_up: start app = /usr/bin/gl_nas_sys
Fri Jan 12 04:00:40 2024 daemon.notice procd: /etc/rc.d/S99gl_nas_sys_up: === nas enable
Fri Jan 12 04:00:40 2024 daemon.info gl-cloud[7520]: (gl-cloud:232) fetch server from: https://gslb-eu.goodcloud.xyz/gslb/getTlsBucket?mac=9483c4a708d6&sn=c3e0cd929cfa461b&ddns=ja708d6&nonce=yFCaSA9sax4XzwFSxUUMR5kIaPX97zXG&sign=bedd407434e925199755018308f42f06&token=9483c4a708d61702320300155
Fri Jan 12 04:00:40 2024 daemon.notice procd: /etc/rc.d/S99webdav_ser: start app = /usr/bin/webdav_ser
Fri Jan 12 04:00:40 2024 daemon.info procd: - init complete -
Fri Jan 12 04:00:40 2024 user.notice ddns-scripts[6715]: glddns: PID ‘6715’ terminated by ‘SIGTERM’ at 2024-01-12 04:00
Fri Jan 12 04:00:40 2024 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) f8:3b:1d:57:25:77
Fri Jan 12 04:00:40 2024 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.15.49 f8:3b:1d:57:25:77
Fri Jan 12 04:00:41 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.15.249 94:83:c4:24:13:02
Fri Jan 12 04:00:41 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.15.249 94:83:c4:24:13:02 GL-A1300
Fri Jan 12 04:00:41 2024 daemon.info gl-cloud[7520]: (gl-cloud:509) connected: true 0 connection accepted
Fri Jan 12 04:00:41 2024 daemon.info gl-cloud[7520]: (gl-cloud:516) connected: 0 connection accepted
Fri Jan 12 04:00:41 2024 kern.warn kernel: [ 28.125989] HTB: quantum of class 10001 is big. Consider r2q change.
Fri Jan 12 04:00:41 2024 kern.warn kernel: [ 28.144459] HTB: quantum of class 10001 is big. Consider r2q change.
Fri Jan 12 04:00:43 2024 user.notice kmwan: config json str={ “op”: 2, “data”: { “cells”: [ { “interface”: “wan”, “netdev”: “eth1”, “track_mode”: “force”, “addr_type”: 4, “tracks”: [ { “type”: “ping”, “ip”: “1.1.1.1” }, { “type”: “ping”, “ip”: “8.8.8.8” }, { “type”: “ping”, “ip”: “208.67.222.222” }, { “type”: “ping”, “ip”: “208.67.220.220” } ] } ] } }
Fri Jan 12 04:00:43 2024 kern.debug kernel: [ 29.542344] [add_dev_config 307]add node success. iface:wan, dev:eth1, ifindex:3
Fri Jan 12 04:00:43 2024 user.notice ddns-scripts[8191]: glddns: PID ‘8191’ started at 2024-01-12 04:00
Fri Jan 12 04:00:44 2024 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) 192.168.15.25 f4:4d:5c:2a:c1:b1
Fri Jan 12 04:00:44 2024 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.15.25 f4:4d:5c:2a:c1:b1
Fri Jan 12 04:00:44 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.15.10 94:83:c4:34:4f:f8
Fri Jan 12 04:00:44 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.15.10 94:83:c4:34:4f:f8 GL-SFT1200
Fri Jan 12 08:26:10 2024 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) c4:36:6c:37:ba:c6
Fri Jan 12 08:26:10 2024 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.15.27 c4:36:6c:37:ba:c6
That would be pretty weird, and I can confirm that this does not happen on my device. So maybe here is a configuration issue.
What firmware do you use?
Do you disable Wi-Fi during nighttime?
Is some different on firmware 4.5.5 that I download before you put it as beta on the webpage?
Can’t tell. When the checksums are different then yes.
On 4.5.5 release 1 it not happen
I downgrade to release 1 and not happen and then try release 3 and same happen so it is some fault with it!!
4.7.0 release3. I have the same problem. Often wifi don`t up after scheduled or manual restart.
