GL-MT6000 - avahi-daemon repeatedly registers/withdraws address record
I have noticed this in the log for some time. Even so, I don't see any connection problems with my devices in the house, but I think at intervals of 3 seconds Log register this ist not a good thing.
Do you have any idea what it could be?
Current Firmware ist 4.6.4 release 1
Fri Sep 13 12:03:13 2024 daemon.info avahi-daemon[4810]: Withdrawing address record for 2xxx:8xxx:5xx:1xxx:9xxx:cxxx:fxxx:3212 on eth1.
Fri Sep 13 12:03:16 2024 daemon.info avahi-daemon[4810]: Registering new address record for 2xxx:8xxx:5xx:1xxx:9xxx:cxxx:fxxx:3212 on eth1..
Fri Sep 13 12:03:16 2024 daemon.info avahi-daemon[4810]: Withdrawing address record for 2xxx:8xxx:5xx:1xxx:9xxx:cxxx:fxxx:3212 on eth1.
Fri Sep 13 12:03:19 2024 daemon.info avahi-daemon[4810]: Registering new address record for 2xxx:8xxx:5xx:1xxx:9xxx:cxxx:fxxx:3212 on eth1.
Fri Sep 13 12:03:19 2024 daemon.info avahi-daemon[4810]: Withdrawing address record for 2xxx:8xxx:5xx:1xxx:9xxx:cxxx:fxxx:3212 on eth1.
Did you enable the IPv6 feature in the Flint 2?
Seems the eth1 (WAN) request the IPv6 from the primary device (ISP router, or others), is the address 2xxx:8xxx:5xx:1xxx:9xxx:cxxx:fxxx:3212 available, or the IPv6 of the primary device works?
Thank you for quick answer.
IPv6 ist enabled.
Mode ist NAT6 selected.
DNS acquisition method ist Automatic selected.
The ipv6 feature of the primary device works ok, its ipv6 internet works ok?
On the main router IPv6 is activated and works correctly.
I see, may I know the Flint 2 ipv6 feature also works ok?
Working IPv6 on Flint 2
i see now, in INTERNET -> Ethernet1 -> Protocol IPv6 have 2 IP Addresses
something, the error what in LOG is register is related with the IP Address 2.
That is right.
This v6 address could not available probably due to address conflicts or someone device or service may be unstable.
Could you try to find this v6 address related to which one primary device, ISP router or primary main router?
