GL-MT6000 (Flint 2) Load Balance help
Hello good morning all,
I recently bought an Flint 2, at home I have 2 ISPs of 1Gbps/1Gbps each, I think having a failover line of 1 Gbps is too much, besides i have thethering from my phone anytime, and my 2 ISP rarely goes down 99% uptime, so I wanted to make use of Load Balance.
The problem is that my main ISP (Vodafone) always has to have the highest priority, because android televisions/boxes (App TV) only work with the Vodafone line (connection mac/token check).
I don't understand the priority ratios (1-10). I've already set the Wan(Vodafone) to 1/2/3 till 10, and the Wan/Lan1 to 10/9/8 till 1, and even though the speedtest gives the Vodafone IP, if I do the test via Wireless (2.4/5Ghz) it gives me the IP of the 2nd provider.
As the Boxes/Televisions are wireless, I ended up having to put the router on Failover because it simple works, the idea was for the 4 Android Box/televisions to use the Vodafone connection and everything else (server/iot/pcs) to use the other 1Gbps connection from the second provider when the Vodafone line was saturated.
Sorry if I didn't make myself understood.
Edit: If helps, i have the first 4 static ip to the Android Boxes/TVs. (192.168.8.10 to14)
Load Balance is automatically triage and selected the uplink (WAN) interface and cannot define which interface takes precedence, it is not Failover.
Your requirement is to specify which clients go to which uplink (WAN) interface, which belongs to policy routing. The GL firmware does not support it at the moment.
You can learn about the third-party plug-in mwan3
https://openwrt.org/docs/guide-user/network/wan/multiwan/mwan3
Thanks @bruce, im on it.
Good morning,
After requesting help here about assigning one ISP to certain devices and a second ISP to others, I’m sharing my experience, which might be useful to someone else in the future. After many hours of discussing the MWAN3 topic with my friend ChatGPT, I finally achieved the result I wanted albeit in a different way but it works, and that’s what matters.
I’d like to thank @bruce for pointing me toward the MWAN3 (Multi-WAN load balancing/failover) documentation.
MWAN3 Multi-WAN Configuration on Flint2 Router (GL-MT6000) / LuCI Console
I configured MWAN3 on my Flint2 router (GL-MT6000) to meet the following goals:
  1. Specific Devices use a dedicated ISP (LigaT 1Gbps).
  2. All Other Devices default to another ISP (Vodafone 1Gbps).
  3. Failover: If the primary ISP fails, traffic is automatically routed to the backup ISP.
Network Overview
  • LAN Subnet: 192.168.8.0/24
  • Primary ISP (Vodafone): Interface wan, Gateway 192.168.1.1
  • Secondary ISP (LigaT): Interface secondwan, Gateway 192.168.2.1
Configuration Files
  1. MWAN3 Configuration
    The MWAN3 setup defines the policies, rules, and failover behavior.
cat /etc/config/mwan3
Key Points:
  1. Interfaces:
    • wan for Vodafone (default).
    • secondwan for LigaT.
  2. Policies:
    • LigaT: Routes traffic exclusively through secondwan.
    • default_poli: Routes traffic through wan by default.
  3. Rules:
    • Traffic from 192.168.8.10 is assigned to the LigaT policy.
    • All other traffic follows the default_poli.
Snippet:
config policy 'LigaT'
option last_resort 'default'
list use_member 'secondwan_only'
config rule 'LigaT_rule'
option src_ip '192.168.8.10'
option dest_ip '0.0.0.0/0'
option use_policy 'LigaT'
config rule 'default_rule'
option use_policy 'default_poli'
2. Network Configuration
The interfaces for the WAN connections are defined as follows:
cat /etc/config/network
Snippet:
config interface 'wan'
option device 'eth1'
option proto 'dhcp'
option metric '1'
config interface 'secondwan'
option device 'lan1'
option proto 'dhcp'
option metric '2'
  • wan (Vodafone) has a lower metric (1), making it the preferred interface.
  • secondwan (LigaT) has a higher metric (2), acting as a backup for failover.
3. Firewall Configuration
The firewall zones are configured to allow traffic forwarding from the LAN to both WAN interfaces.
cat /etc/config/firewall
Snippet:
config zone
option name 'wan'
list network 'wan'
list network 'secondwan'
option masq '1'
option input 'DROP'
option forward 'REJECT'
config forwarding
option src 'lan'
option dest 'wan'
Behavior
  1. Device Routing:
    • 192.168.8.10: Uses the LigaT ISP exclusively via the LigaT_rule and secondwan interface.
    • Other Devices: Use Vodafone by default through the default_poli policy.
  2. Failover:
    • If the Vodafone (WAN) connection fails, all devices fall back to the LigaT ISP via secondwan.
    • This is managed automatically by MWAN3's tracking (ping) and failover mechanisms.
Example of Interface Status:
mwan3 status
Output:
interface wan is offline and tracking is active
interface secondwan is online and tracking is active
Current ipv4 policies:
LigaT:
secondwan (100%)
default_poli:
default
Testing
  1. Failover:
    • Disconnected the Vodafone (WAN) cable.
    • Verified that traffic from all devices switched to the LigaT ISP seamlessly.
  2. Device-Specific Routing:
    • Performed traceroute and IP tests from 192.168.8.10:
      • Traffic was routed through the LigaT ISP (192.168.2.1).
  3. Restoration:
    • Reconnected the Vodafone (WAN) cable.
    • Devices returned to the default ISP (Vodafone).
Conclusion
This MWAN3 setup achieves:
  1. Device-Specific Routing: Assign specific devices to use a particular ISP.
  2. Failover: Automatic switching between ISPs when the primary connection fails.
The configuration can easily be extended to add more devices or implement load balancing if needed.
Thank you very much for your sharing.
Write the application of MWAN3 very detailed, I believe it will help many users, as well as some people in need on the Internet.
