Test environment: GL-MT6000 running GL.iNet OpenWrt 25 beta build (mt6000-op-4.9.1-op25_beta1-1032-0707-1783421695), mt76 driver, LuCI.
The values below were verified with:
iw reg get
iw phy phy0 info | grep dBm
iw phy phy1 info | grep dBm
Measured Results
Panama (PA)
2.4 GHz: 33 dBm
5 GHz CH100–144: 30 dBm
5 GHz CH149–165: 32 dBm
United States (US)
2.4 GHz: 33 dBm
Canada (CA)
2.4 GHz: 33 dBm
5 GHz CH36–48: 23 dBm
5 GHz CH52–144: 26 dBm
Australia (AU)
2.4 GHz: 33 dBm
5 GHz CH52–64: 20 dBm
5 GHz CH100–144: 26 dBm
Brazil (BR)
2.4 GHz: 30 dBm
5 GHz CH36–144: 27 dBm
5 GHz CH149–165: 30 dBm
Mexico (MX)
2.4 GHz: 20 dBm
5 GHz CH36–48: 17 dBm
5 GHz CH52–144: 24 dBm
Peru (PE)
2.4 GHz: 20 dBm
United Kingdom (GB)
2.4 GHz: 20 dBm
5 GHz CH149–165: 23 dBm
Albania (AL)
2.4 GHz: 20 dBm
5 GHz CH100–140: 26 dBm
5 GHz CH149–165: 13 dBm
Bolivia (BO)
2.4 GHz: 20 dBm
5 GHz CH52–64: 30 dBm
Additional Observation
When TX Power = Driver Default, LuCI reports:
2.4 GHz = 33 dBm
5 GHz = 32 dBm (Channel 149)
and the GL.iNet interface still displays Wi-Fi Power = Max.
If I manually enter exactly the same TX power values (33/32 dBm), the GL.iNet interface changes from Max to High, even though the actual transmit power remains the same.
Current Configuration
Country: Panama
2.4 GHz: Channel 6 (HE20)
5 GHz: Channel 149 (HE80)
TX Power: Driver Default
These are simply measurements from my device using Linux wireless tools. Please use only settings that comply with your local regulations.
