GL-MT6000 install python
Hello, I am new to Glinet router.
Can we install python 3 to Flint 2? will this be too heavy for it?
Or there is other recommanded version?
Thanks!
Yes, you can install Python 3 on the Flint 2.
Just SSH into the router and run:
opkg update && opkg install python3
In terms of storage space alone, I don't think it will be an issue.
If we're talking about CPU/memory usage, that may depend on your specific application scenario.
You could also consider installing micropython, but note that you would need to adjust your scripts or programs for compatibility.
