Please forgive me if this has been answered elsewhere, but I have searched and cannot find an answer.
I received my GL-MT6000 a few days ago and have been playing with it since trying to become familiar with the openwrt configuration firmware – LuCi. I am an ignorant network noob and don’t understand most of the settings (I just try to copy existing examples). YouTube has been helpful.
My router shows it is running firmware 4.6.2 (OpenWrt 21.02-SNAPSHOT r15812+1075-46b6ee7ffc Kernel Version 5.4.238). The wan port is connected to my primary router by cable for its internet and my desktop pc is connected to lan port 2. This is for testing and setup.
I have been using a one router home network setup for years. I am currently running a Netgear R7800 on dd-wrt giving me Primary, Guest and IOT networks. Using vlans, the Guest and IOT networks each have one ethernet port assigned, and the remaining two ports are in the Primary network. Each network has separate 2.4 and 5.0 wireless SSIDs (virtual access points). Each network is on its own bridge (br0, br1, br2) with its own subnet.
I want to create a similar configuration on the GL-MT6000 (IS THIS POSSIBLE ?) but have not been able to get the wireless IOT networks working. My setup procedure is to log into the GL interface, set system time and then activate both guest networks (2.4 and 5.0). Then I go to the advanced settings and log into the LuCi interface.
When I go to “Network-Interfaces” menu item in LuCi I get this message:
“Network ifname configuration migration
The existing network configuration needs to be changed for LuCI to function properly.
Upon pressing "Continue", ifname options will get renamed and the network will be restarted to apply the updated configuration.”
After hitting “Continue” I proceed with my setup.
At the “Network-Wireless” page I click “Add” next to the generic wireless for 2.4 and 5.0 radios.
Using the guest network interfaces in LuCi as examples, I configured IOT network wireless and interfaces for 2.4 and 5.0 networks. However, they never activate and each shows a message “Wireless is not associated” and the networks are disabled. I assume this means the interfaces are not associated/connected with the physical radios. How do I get them associated with the physical radios? (I’ll tackle my vlan port setup after I get the wireless setup worked out.)
Any help and clarification on the setup/configuration process for adding an IOT network is appreciated.
Thanks
