GL-MT6000 Plugins Query
Hello everyone,
Apologies if this isn't the ideal category for my question. I've recently started using the GL-MT6000 and am really enjoying it! I’m keen to explore its full potential, so I was wondering if anyone could recommend a list of the top 10 plugins worth looking into? I’d love to get more out of my router and explore some new functionalities.
Thanks in advance for any suggestions!
Depending on what needs need to be met or realized, forum users probably can recommend some plug-ins, instead of adding needs to yourself without knowing any needs. :slightly_smiling_face:
If you have a hard drive connected to USB port, you should get Luci-app-hd-idle, so you can set the HDD to sleep. Only needed it if you are using a spindle drive and not a solid drive.
