GL-MT6000 Slow Upload speed
Hi All!
I've been using the Beta firmware 4.6.2
So far everything is working great, except for 1 issue. My Upload speed is horrendous with the Flint 2.
I have Verizon Fios, and can match expected provisioned rate for download (~900-940 Mbps), but the upload speeds only hits around 130 Mbps max (out of an expect 880 Mbps). This is strictly on LAN connection, no WiFi testing .I do not have SQM enabled, just SW/HW Acceleration.
Anyone have any tips or clues for me?
Please do a test directly from the router itself.
Via SSH:
wget https://install.speedtest.net/app/cli/ookla-speedtest-1.2.0-linux-aarch64.tgz && tar xzf ookla-speedtest-1.2.0-linux-aarch64.tgz && ./speedtest
seems work well for me
Thank you both for responding. Ran a speed test as request, verified slow upload speed:
Please let me know what connectivity of the WAN of the MT6000 with Verizon Fios? Cable WAN or Repeater, or other methods?
If the cable wan connectivity between the Verizon Fios - MT6000, please use the PC to connect to Verizon Fios do a speedtest, to see how about the LAN speed from Verizon Fios.
What if you connect your computer directly to the ISP cable and test the upload?
Duplicate issue here: FiOS upload speed hampered with Flint 2 - #6 by JustAnotherGLiNetUse
I tried running the command @admon suggested, but get the following error
There was a space inside the command, I fixed it:
Thanks @admon. This is the error I'm getting, can you advise?
You can also just download speedtest from the Plug-ins page in the GL.iNet firmware UI.
Glad I found this topic. I was having the same issue... should be getting 1gbps up and down, was only getting 180mbps up. Download was closer to 900. I just got the GliNet Flint 2. My previous router was only consistently hitting 300 up so I do think it's an issue on Verizon's end. But I tried putting a 1gbe switch between the ONT and router and now I'm getting closer to 600mbps upload, which I can live with.
There is no problem with Flint2 speeds in 4.8op24:
OpenWrt 24.10.2, r28739-d9340319c6
root@GL-MT6000:~# ./speedtest
Speedtest by Ookla
  Server: Iliad Free SAS - Marseille (id: 32565)
     ISP: Free SAS
Idle Latency: 8.17 ms (jitter: 0.08ms, low: 8.12ms, high: 8.29ms)
Download: 2316.95 Mbps (data used: 2.6 GB)
87.99 ms (jitter: 54.36ms, low: 8.43ms, high: 468.07ms)
Upload: 2307.45 Mbps (data used: 2.2 GB)
11.01 ms (jitter: 0.57ms, low: 8.51ms, high: 16.46ms)
Packet Loss: 0.0%
