GL-MT6000 Some Devices Unable to connect
I have a few devices that are unable to connect to my Flint2, I have tested them connecting to a mobile hotspot and they work fine. I tried troubleshooting but haven't had much luck, the log messages I get for one of these devices are below when searching for the devices MAC address. Any help would be great
Sun Nov 24 21:46:23 2024 kern.warn kernel: [966709.202693] 7986@C13L2,MacTableInsertEntry() 1577: New Sta:38:7a:cc:25:c1:55
Sun Nov 24 21:46:23 2024 kern.notice kernel: [966709.426131] 7986@C08L3,ap_cmm_peer_assoc_req_action() 1714:  Recv Assoc from STA - 38:7a:cc:25:c1:55
Sun Nov 24 21:46:23 2024 kern.notice kernel: [966709.435713] 7986@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Sun Nov 24 21:46:23 2024 kern.notice kernel: [966709.444897] 7986@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Sun Nov 24 21:46:23 2024 kern.notice kernel: [966709.451101] 7986@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Sun Nov 24 21:46:23 2024 kern.notice kernel: [966709.582402] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Sun Nov 24 21:46:23 2024 kern.notice kernel: [966709.591450] 7986@C15L3,PeerPairMsg2Action() 6303: ===>Receive msg 2
Sun Nov 24 21:46:23 2024 kern.notice kernel: [966709.598462] 7986@C15L3,WPABuildPairMsg3() 5595: <=== send Msg3 of 4-way
Sun Nov 24 21:46:23 2024 kern.notice kernel: [966709.622085] 7986@C15L3,PeerPairMsg4Action() 6734: ===>Receive msg 4
Sun Nov 24 21:46:23 2024 kern.warn kernel: [966709.633772] 7986@C15L2,PeerPairMsg4Action() 7098: AP SETKEYS DONE(ra0) - AKMMap=WPA3PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=9 from 38:7a:cc:25:c1:55
Sun Nov 24 21:46:46 2024 daemon.info dnsmasq-dhcp[20189]: DHCPDISCOVER(br-lan) 38:7a:cc:25:c1:55
Sun Nov 24 21:46:46 2024 daemon.info dnsmasq-dhcp[20189]: DHCPOFFER(br-lan) 192.168.0.213 38:7a:cc:25:c1:55
Sun Nov 24 21:46:46 2024 daemon.info dnsmasq-dhcp[20189]: DHCPREQUEST(br-lan) 192.168.0.213 38:7a:cc:25:c1:55
Sun Nov 24 21:46:46 2024 daemon.info dnsmasq-dhcp[20189]: DHCPACK(br-lan) 192.168.0.213 38:7a:cc:25:c1:55
Sun Nov 24 21:47:29 2024 kern.warn kernel: [966775.707392] 7986@C01L2,wifi_sys_disconn_act() 1002:  wdev_idx=0
Sun Nov 24 21:47:29 2024 kern.notice kernel: [966775.713656] 7986@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Sun Nov 24 21:47:29 2024 kern.warn kernel: [966775.720875] 7986@C13L2,MacTableDeleteEntry() 1938: Del Sta:38:7a:cc:25:c1:55
Sun Nov 24 21:47:29 2024 kern.notice kernel: [966775.728203] 7986@C08L3,ap_peer_deauth_action() 437: AUTH - receive DE-AUTH(seq-86) from 38:7a:cc:25:c1:55, reason=3
Please share your Wi-Fi settings (channel, encryption, bandwidth) and what kind of devices you want to connect.
I have attached a screenshot. I have tried lot of different settings with the security and WiFi without any luck.
One of the devices is a pet feeder and the other is a smart meter for electric that connects to WiFi. Both only support 2.4GHz. both I tried connecting to a mobile hot spot and they worked fine.
The pet feeder used to connect and I believe it may have stopped with the latest update but I need to downgrade to test this
Which firmware are you running?
I'm running 4.6.8
