I own the GL-MT6000 router and today I decided to migrate to OpenWrt by the method using Uboot Debrick via Uboot - GL.iNet Router Docs 3 everything was set according to the recommendations in the attached link, but I noticed that packets were being lost on the ping with attached information, I received this device with Uboot with problems?
You can see that after installation the ping was normal!
C:\Windows\System32>ping -t 192.168.1.1
Pinging 192.168.1.1 with 32 bytes of data:
Reply from 192.168.1.2: Destination host unreachable.
Reply from 192.168.1.1: bytes=32 time=1001ms TTL=128
Reply from 192.168.1.1: bytes=32 time<1ms TTL=128
Request timed out.
Request timed out.
Reply from 192.168.1.1: bytes=32 time=2ms TTL=128
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.1.1: bytes=32 time=1005ms TTL=128
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.1.1: bytes=32 time=1979ms TTL=128
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.1.1: bytes=32 time<1ms TTL=128 HERE I UPLOADED IMAGE AND START TRANSFER
Request timed out.
Request timed out.
General failure.
General failure.
General failure.
Reply from 192.168.1.1: bytes=32 time=443ms TTL=128
Request timed out.
Reply from 192.168.1.1: bytes=32 time<1ms TTL=64 OpenWrt start works
Ping statistics for 192.168.1.1:
Packets: Sent = 327, Received = 275, Lost = 52 (15% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1979ms, Average = 18ms
Control-C
attached to the settings with the network card, it is something strange in my configuration to disturb Uboot?
It is normal for it to work like this, what can I do to see where the problem is?
