have tested with mikrotik router getting the speed 1gbps
with MT6000 getting:
Is QoS on?
Is hardware acceleration On?
Which firmware are you running?
What are your wifi settings?
VPN or Wireguard?
Have tried qos on/off, hw acceleration on/off, no vpn enabled.
Firmware: 4.6.8
Was testing with WiFi off.
No difference at all.
What steps have you taken to find the cause of the problem?
The problem still exists. I’m looking for answer what the cause is.
Only way to know is process of elimination. You can start from scratch or work your way backwards.
What are you on about?
Thats how you hopefully find an answer. Process of elimination.
I thought I’ve answered your question that I went through the process of elimination which didn’t help.
You have to do the rest on your own from here. Wipe the router and start from scratch. Start testing your network, settings, cables, etc etc. You have to find the needle in the hay stack and keep detailed notes for your self during your testing process.
