GL-MT6000 VPN Problem
Hello, I use the Flint 2 with the 4.5.5 version.
It doesn’t matter whether Nordvpn is via the implemented app or Manuel VPN.
Not even with Surfshark.
Tried everything OpenVPN or Wiregaurd with no success.
If I play a version 4.5.3 it works but then there are WiFi problems
Please post your log files so we can understand whats going on.
There is no known issue with WG VPN in 4.5.5; at least not yet.
Sun Jan 14 22:20:26 2024 daemon.info dnsmasq[1]: started, version 2.89 cachesize 1000
Sun Jan 14 22:20:26 2024 daemon.info dnsmasq[1]: DNS service limited to local subnets
Sun Jan 14 22:20:26 2024 daemon.info dnsmasq[1]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset nftset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Sun Jan 14 22:20:26 2024 daemon.info dnsmasq[1]: UBus support enabled: connected to system bus
Sun Jan 14 22:20:26 2024 daemon.warn dnsmasq[1]: warning: ignoring resolv-file flag because no-resolv is set
Sun Jan 14 22:20:26 2024 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 192.168.9.100 – 192.168.9.249, lease time 12h
Sun Jan 14 22:20:26 2024 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 192.168.50.15 – 192.168.50.249, lease time 12h
Sun Jan 14 22:20:26 2024 daemon.info dnsmasq[1]: using nameserver 9.9.9.9#53
Sun Jan 14 22:20:26 2024 daemon.info dnsmasq[1]: using nameserver 149.112.112.112#53
Sun Jan 14 22:20:26 2024 daemon.info dnsmasq[1]: using only locally-known addresses for test
Sun Jan 14 22:20:26 2024 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Sun Jan 14 22:20:26 2024 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Sun Jan 14 22:20:26 2024 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Sun Jan 14 22:20:26 2024 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Sun Jan 14 22:20:26 2024 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Sun Jan 14 22:20:26 2024 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Sun Jan 14 22:20:26 2024 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Sun Jan 14 22:20:26 2024 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Sun Jan 14 22:20:32 2024 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) 192.168.50.210 6a:ff:7a:06:d8:b0
Sun Jan 14 22:20:32 2024 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.50.210 6a:ff:7a:06:d8:b0
Sun Jan 14 22:20:50 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Sun Jan 14 22:20:50 2024 daemon.notice netifd: Network device ‘wgclient’ link is down
Sun Jan 14 22:20:50 2024 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) 192.168.50.210 6a:ff:7a:06:d8:b0
Sun Jan 14 22:20:50 2024 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.50.210 6a:ff:7a:06:d8:b0
Sun Jan 14 22:20:50 2024 daemon.notice netifd: wgclient (16938): sh: 1: unknown operand
Sun Jan 14 22:20:50 2024 daemon.info dnsmasq[1]: exiting on receipt of SIGTERM
Sun Jan 14 22:20:50 2024 daemon.notice netifd: wgclient (16938): udhcpc: started, v1.36.1
Sun Jan 14 22:20:50 2024 daemon.notice netifd: wgclient (16938): udhcpc: broadcasting discover
Sun Jan 14 22:20:53 2024 daemon.notice netifd: wgclient (16938): udhcpc: no lease, failing
Sun Jan 14 22:20:54 2024 daemon.notice netifd: Interface ‘wgclient’ is now down
Sun Jan 14 22:20:54 2024 daemon.info dnsmasq[1]: started, version 2.89 cachesize 1000
Sun Jan 14 22:20:54 2024 daemon.info dnsmasq[1]: DNS service limited to local subnets
Sun Jan 14 22:20:54 2024 daemon.info dnsmasq[1]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset nftset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Sun Jan 14 22:20:54 2024 daemon.info dnsmasq[1]: UBus support enabled: connected to system bus
Sun Jan 14 22:20:54 2024 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 192.168.9.100 – 192.168.9.249, lease time 12h
Sun Jan 14 22:20:54 2024 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 192.168.50.15 – 192.168.50.249, lease time 12h
Sun Jan 14 22:20:54 2024 daemon.info dnsmasq[1]: using nameserver 9.9.9.9#53
Sun Jan 14 22:20:54 2024 daemon.info dnsmasq[1]: using nameserver 149.112.112.112#53
Sun Jan 14 22:20:54 2024 daemon.info dnsmasq[1]: using only locally-known addresses for test
Sun Jan 14 22:20:54 2024 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Sun Jan 14 22:20:54 2024 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Sun Jan 14 22:20:54 2024 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Sun Jan 14 22:20:54 2024 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Sun Jan 14 22:20:54 2024 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Sun Jan 14 22:20:54 2024 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Sun Jan 14 22:20:54 2024 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Sun Jan 14 22:20:54 2024 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Sun Jan 14 22:20:54 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Sun Jan 14 22:21:01 2024 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Sun Jan 14 22:21:01 2024 kern.info kernel: [45019.337152] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Sun Jan 14 22:21:01 2024 daemon.notice netifd: Network device ‘wgclient’ link is up
Sun Jan 14 22:21:01 2024 daemon.notice netifd: Interface ‘wgclient’ is now up
Sun Jan 14 22:21:02 2024 daemon.info dnsmasq[1]: exiting on receipt of SIGTERM
Sun Jan 14 22:21:02 2024 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)
Sun Jan 14 22:21:05 2024 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Mullvad FromApp group_1325 group_644 group_3610 group_8862 group_2449 peer_2003 peer_2002 CONFIG_cfg030f15_ports=
Sun Jan 14 22:21:05 2024 daemon.info dnsmasq[1]: started, version 2.89 cachesize 1000
Sun Jan 14 22:21:05 2024 daemon.info dnsmasq[1]: DNS service limited to local subnets
Sun Jan 14 22:21:05 2024 daemon.info dnsmasq[1]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset nftset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Sun Jan 14 22:21:05 2024 daemon.info dnsmasq[1]: UBus support enabled: connected to system bus
Sun Jan 14 22:21:05 2024 daemon.warn dnsmasq[1]: warning: ignoring resolv-file flag because no-resolv is set
Sun Jan 14 22:21:05 2024 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 192.168.9.100 – 192.168.9.249, lease time 12h
Sun Jan 14 22:21:05 2024 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 192.168.50.15 – 192.168.50.249, lease time 12h
Sun Jan 14 22:21:05 2024 daemon.info dnsmasq[1]: using nameserver 9.9.9.9#53
Sun Jan 14 22:21:05 2024 daemon.info dnsmasq[1]: using nameserver 149.112.112.112#53
Sun Jan 14 22:21:05 2024 daemon.info dnsmasq[1]: using only locally-known addresses for test
Sun Jan 14 22:21:05 2024 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Sun Jan 14 22:21:05 2024 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Sun Jan 14 22:21:05 2024 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Sun Jan 14 22:21:05 2024 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Sun Jan 14 22:21:05 2024 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Sun Jan 14 22:21:05 2024 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Sun Jan 14 22:21:05 2024 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Sun Jan 14 22:21:05 2024 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Sun Jan 14 22:21:14 2024 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) 192.168.50.210 6a:ff:7a:06:d8:b0
Sun Jan 14 22:21:14 2024 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.50.210 6a:ff:7a:06:d8:b0
Sun Jan 14 22:21:19 2024 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) 60:01:94:be:5b:be
Sun Jan 14 22:21:19 2024 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.50.136 60:01:94:be:5b:be
Sun Jan 14 22:21:19 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.50.136 60:01:94:be:5b:be
Sun Jan 14 22:21:19 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.50.136 60:01:94:be:5b:be ESP_BE5BBE
Sun Jan 14 22:21:32 2024 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) 192.168.50.210 6a:ff:7a:06:d8:b0
Sun Jan 14 22:21:32 2024 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.50.210 6a:ff:7a:06:d8:b0
Sun Jan 14 22:21:39 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Sun Jan 14 22:21:39 2024 daemon.notice netifd: Network device ‘wgclient’ link is down
Sun Jan 14 22:21:40 2024 daemon.notice netifd: wgclient (19335): sh: 1: unknown operand
Sun Jan 14 22:21:40 2024 daemon.info dnsmasq[1]: exiting on receipt of SIGTERM
Sun Jan 14 22:21:40 2024 daemon.notice netifd: wgclient (19335): udhcpc: started, v1.36.1
Sun Jan 14 22:21:40 2024 daemon.notice netifd: wgclient (19335): udhcpc: broadcasting discover
Sun Jan 14 22:21:43 2024 daemon.notice netifd: wgclient (19335): udhcpc: no lease, failing
Sun Jan 14 22:21:43 2024 daemon.notice netifd: Interface ‘wgclient’ is now down
Sun Jan 14 22:21:43 2024 daemon.info dnsmasq[1]: started, version 2.89 cachesize 1000
Sun Jan 14 22:21:43 2024 daemon.info dnsmasq[1]: DNS service limited to local subnets
Sun Jan 14 22:21:43 2024 daemon.info dnsmasq[1]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset nftset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Sun Jan 14 22:21:43 2024 daemon.info dnsmasq[1]: UBus support enabled: connected to system bus
Sun Jan 14 22:21:43 2024 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 192.168.9.100 – 192.168.9.249, lease time 12h
Sun Jan 14 22:21:43 2024 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 192.168.50.15 – 192.168.50.249, lease time 12h
Sun Jan 14 22:21:43 2024 daemon.info dnsmasq[1]: using nameserver 9.9.9.9#53
Sun Jan 14 22:21:43 2024 daemon.info dnsmasq[1]: using nameserver 149.112.112.112#53
Sun Jan 14 22:21:43 2024 daemon.info dnsmasq[1]: using only locally-known addresses for test
Sun Jan 14 22:21:43 2024 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Sun Jan 14 22:21:43 2024 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Sun Jan 14 22:21:43 2024 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Sun Jan 14 22:21:43 2024 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Sun Jan 14 22:21:43 2024 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Sun Jan 14 22:21:43 2024 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Sun Jan 14 22:21:43 2024 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Sun Jan 14 22:21:43 2024 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Sun Jan 14 22:21:44 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Does work ip6 wireguard? I thought vpn working only ip4 :thinking:
IPv6 is out
Did I got right that on 4.5.3 everything worked?
VPN yes!! at 4.5.3
but
Wifi problems.
With the VPN I also noticed that despite changing servers several times with NORDVPN and different protocols and together with Nordvpn, I never got over 90 to 110 mbit. With a 200 mbit line.
With Surfshark I can get up to 175mbit
But they are no longer at 4.5.5 until now. But VPN problems.
While upgrading: did you select that the current settings should be preserved?
No, I always do a fresh install without any legacy issues.
But I also tried from 4.5.3 to 4.5.5 and retaining data doesn’t help either.
I noticed your screenshot wgclient does not support protocol. Could be that problem?
Nah, that is normal.
That should be fine, since gl-inets version is different than the normal OpenWrt version.
But i dont see a lan interface in that screenshot, though theres a mentoin theres one in the logs.
So that makes me wonder if the router is set into repeater modus, and if or the lan interface is needed for the wgclient script.
That should be good :+1:, so this is not the issue.
Edit:
Can you post the config from dhcp perhaps?
I wonder what the ranges are, i see some possible illegal/invalid start ips here like: 192.168.9.100
192.168.50.15 - 249
this is the set area. Everything is identical to 4.5.3
Hmm :thinking:, sounds ok to me but just verify in luci to be sure.
I want to see the limit it shows there, if that combined with 192.168.50.15 points above 254 its wrong :slight_smile: , might not fix your wg issue directly but it insta alerted me :wink:
This can be done in luci → network → interfaces → lan (edit button) → dhcp server (tab).
But it wouldn’t matter, even with a completely new install without any settings, the problem still exists under 4.5.5
Yea they look fine, it could still mather if it was wrong because the broadcasting would not work as expected, but .255 is the broadcast address so.
I think the contents of network, firewall and wireguard are needed just to be sure theres nothing wrong, just make sure you dont disclose any private info like public ip👍
Perhaps it is a new issue in the firmware :wink:
Try reset vpn? I think problem wrong private key :thinking: I mean start over create vpn server/client.
Tried everything.
The same settings work under version 4.5.3, so it seems to be due to version 4.5.5.
Various providers were tested and almost all the settings that I could make
