Hi recently a couple of months ago I bought GL-MT6000 I have my Nord VPN account and it is linked to the router but I can’t get it to work with the OpenVPN protocol it just says that the file does not exist, I have already factory reset my router 2 times and always the same error appears with WireGuard everything works fine.
Thu Feb 22 20:39:40 2024 daemon.notice netifd: ovpnclient (3427): [!] Section webdav_wan specifies unknown option 'dest_proto'
Thu Feb 22 20:39:40 2024 daemon.notice netifd: ovpnclient (3427): [!] Section @forwarding[0] is disabled, ignoring section
Thu Feb 22 20:39:40 2024 daemon.notice netifd: ovpnclient (3427): [!] Section @forwarding[1] is disabled, ignoring section
Thu Feb 22 20:39:40 2024 daemon.notice netifd: ovpnclient (3427): [!] Section wgclient2wan option 'src' specifies invalid value 'wgclient'
Thu Feb 22 20:39:40 2024 daemon.notice netifd: ovpnclient (3427): [!] Section wgclient2wan skipped due to invalid options
Thu Feb 22 20:39:40 2024 daemon.notice netifd: ovpnclient (3427): [!] Section lan2wgclient option 'dest' specifies invalid value 'wgclient'
Thu Feb 22 20:39:40 2024 daemon.notice netifd: ovpnclient (3427): [!] Section lan2wgclient skipped due to invalid options
Thu Feb 22 20:39:40 2024 daemon.notice netifd: ovpnclient (3427): [!] Section guest2wgclient option 'dest' specifies invalid value 'wgclient'
Thu Feb 22 20:39:40 2024 daemon.notice netifd: ovpnclient (3427): [!] Section guest2wgclient skipped due to invalid options
Thu Feb 22 20:39:40 2024 daemon.notice netifd: ovpnclient (3427): [!] Section nat6 option 'reload' is not supported by fw4
Thu Feb 22 20:39:40 2024 daemon.notice netifd: ovpnclient (3427): [!] Section vpn_server_policy option 'reload' is not supported by fw4
Thu Feb 22 20:39:40 2024 daemon.notice netifd: ovpnclient (3427): [!] Section gls2s option 'reload' is not supported by fw4
Thu Feb 22 20:39:40 2024 daemon.notice netifd: ovpnclient (3427): [!] Section gls2s specifies unreachable path '/var/etc/gls2s.include', ignoring section
Thu Feb 22 20:39:40 2024 daemon.notice netifd: ovpnclient (3427): [!] Section glblock option 'reload' is not supported by fw4
Thu Feb 22 20:39:40 2024 daemon.notice netifd: ovpnclient (3427): [!] Automatically including '/usr/share/nftables.d/chain-pre/dstnat/00-dhcp-no-flow_offloading.nft'
Thu Feb 22 20:39:40 2024 daemon.notice netifd: ovpnclient (3427): [!] Automatically including '/usr/share/nftables.d/chain-pre/forward_guest/01-forward_bypass_domain.nft'
Thu Feb 22 20:39:40 2024 daemon.notice netifd: ovpnclient (3427): [!] Automatically including '/usr/share/nftables.d/chain-pre/forward_lan/01-forward_bypass_domain.nft'
Thu Feb 22 20:39:40 2024 daemon.notice netifd: ovpnclient (3427): [!] Automatically including '/usr/share/nftables.d/chain-pre/mangle_output/01-process_mark.nft'
Thu Feb 22 20:39:40 2024 daemon.notice netifd: ovpnclient (3427): [!] Automatically including '/usr/share/nftables.d/chain-post/mangle_output/out_conn_mark_restore.nft'
Thu Feb 22 20:39:40 2024 daemon.notice netifd: ovpnclient (3427): cat: can't open '/tmp/run/ovpn_resolved_ip': No such file or directory
