While I’m more than happy that my new GL-MT6000 has considerable wireless range, I noticed that it transmits at 36dBm (4 watts) on both 2.4 GHz and 5 GHz.
In the European Union, more than 1 watt (30 dBm) seems to be not allowed.
2.4 GHz band: In the 2.4 GHz band, which covers the frequencies 2.400 to 2.4835 GHz, the maximum transmission power is generally limited to 20 dBm (100 mW).
5 GHz band: In the 5 GHz band, the regulations are more complex as this band is divided into several sub-bands, each of which has different regulations. In many cases, the maximum transmission power is between 200 mW and 1 W (23 to 30 dBm), depending on the specific frequency ranges and whether indoor or outdoor use is involved.
Interestingly, my WLAN is already set to “Germany” in Luci.
Since this may be a bug that might need to be corrected, I wanted to let you know.
I don’t know anything about Wi-Fi power, but it seemed very strange to me that the values here were so high, while the Flint1 was locked at 20dBm.
Can gl-inet give the option to adjust the WiFi power in the GUI as an advanced feature? As I will sit close to mine, i am glad my head won’t be melted by the latest firmware
Since I don’t know what exactly you are trying to achieve: Spoken for this update, it will reset the Wi-Fi power. So as soon as you update, you won’t be able to use more power than allowed anymore.
Mine looked like it was shipping out of China and then this morning it says it’s been delayed to 11th Dec due to operational reasons! Jeez, so much for FedEx.
