GL-MT6000 Wireless schedule feature request
Hi.
I'm a proud possessor of GL-MT6000.
I was wondering if it was possible to include in one of the next official firmwares the possibility of setting the use of wi-fi at certain times of the day.
I know of the possibility of doing it via cron or script on Openwrt, but I was looking for something more immediate and official.
Thanks for the work you do on this router and sorry for the inconvenience
Dario
This feature exists already, at least for turning on / off during night, for example. See Scheduled Tasks - GL.iNet Router Docs 4
I knew this feature.
But it is limited to a single time setting, while it would be appropriate to create a mask with the possibility of configuring multiple time intervals in which wireless networks can be activated/deactivated
This but sunrise, or sunset time - similar to: How to Set up Schedule, Away Mode, and Timer for Smart Plug/Bulb/Switch in Tapo App | Tapo
I've noted your request for wireless networks customised multiple on-off times and we plan to add this feature in the next version (v4.8), stay tuned!
