I have a new Brume set up, but the internet (WAN) speed drops. I have a 500mb/s speed internet ( NOS Madeira ) , modem gives the same speed, when I connect my pc directly.
Now I connected Brume, few days I got the same speed, but now its only 200-250mb/s speed.
Same problem is after factory reset.
i’ve tried with my precious routers (ER-X and USG from Unifi) and no speed problems.
Wierd, because Unifi routers specs are not even close to brume power.
Edit: I also tried previous firmware, same issue, max 260-270. First it bursts to 350 and then drops down to 260-270.
How are you doing the speed test, loaded or unloaded. For a loaded test I have all my devices on and downloading stuff from the internet and test through FAST.com. Unloaded use Bufferbloat and Internet Speed Test - Waveform and have only one computer connected with background process off. Most ISP will give you a throttle boost for 10-20 sec up to your max speed and then throttle down until more bandwidth is available.
Hi!
No traffic, only my pc without local network. I’ve tested with fast.com and speedtest.net.
Point is that in idle mode with my pc and unifi routers the speed is ok, only problem is with Brume with default configuration.
So waveform shows that the USG has high latency under load and the Brume has much lower latency under load. The majority of the the time you get a 100Mbps with a burst up to 421.08mbps.(from data provided)
You have 31 minutes between each speedtest in the early afternoon so I would call that a busy time for most ISP(Business day is concluding and such)
If its possible I would try for a 12-3am speedtests(my experience were i got sustained speeds at or above what was promised by ISP.) Make sure you have one computer background services turned off wired using the network for Waveform.
Could be QOS on the routers needs some changes or SQM use.
The Brume is running the best speed at the lowest latency. I do not work for and I am not directly associated with GL.iNet
I’ve made so many test, most important that tests are made at short intervals. That was just a sampler:)
Now I got another problem - over night my AGH “port forward for localhost solution” stopped working.
DNS don’t resolve.
Do you know the best solution so that AGH may show every user, not all in the same “localhost”?
But why did it lost connection with upstream DNS server?
I’ve tried several different upstream servers ( I used nextdns) and it worked over 2 months.
I already used a NUC for AGH and Unifi Controller with USG, but I purchased the Brume, so that I don’t have to use NUC for AGH and I replaced Unifi to Pepwave.
If I can’t get the AGH to work with Brume, then it’s useless - I need to see every user, because I have children to block certain applications.
Right now I’m testing both NextDNS and AdGuard DNS, and i’m not satisfied.
edit: seems that upstream DNS problem was only with DoH NexttDNS , NextDNS dns ip worked, also google dns.
Now using Adguard DNS and its working.
I don’t want to send my dns queries to google etc:)
Are you using the correct adguard home settings page? Usually is the default gateway with :3000 after it. If you are using DoH or DoT don’t forget to bootstrap the DNS servers with correct IPs.
