hi, i bought the alfa awus1900 , and when i connect it to the brume, it doesn’t recognise it . any chanche that a futur update of brume can make it works?
USB Adapter RTL8812AU should work on Brume :
Is it possible to use the external WiFi dongle RTL8812AU (for the better range) to connect to the hotel WiFi router - and to connect my devices to the internal (weaker) WiFi of the Brume-W ?
There is another old post about awus1900 (RTL8814AU chipset)
Hello!
Has anyone been able to run a USB dongle with an RTL8814 chipset on a Gl.iNet device?
Is that possible?
I see that RTL8812AU can work ok but no information about 8814AU, I think the only difference is that 8814 can support 4 antennae.
Thank you
