I’m trying to troubleshoot a simple setup where I have ethernet going into the WAN port from my provider (Ting, if curious) and then from the LAN port to a desktop computer. My ISP uses DHCP and I get Internet service on the desktop computer for exactly 3 minutes and then it fails. If I go into OpenWrt to Network → Interfaces and restart the the DHCP client for the WAN it will give a new 3 minute period of functionality.
Has anyone seen this before? I’m a loss and didn’t see any issues in the forums similar to this.
Thanks for writing back. Here is the system log, then failure of Internet connection after 3 minutes and then restarting DHCP on WAN interface to temporarily restore:
Sat Nov 6 00:31:48 2021 daemon.info dnsmasq-dhcp[2543]: DHCPDISCOVER(br-lan) 68:5b:35:a3:e0:54
Sat Nov 6 00:31:48 2021 daemon.info dnsmasq-dhcp[2543]: DHCPOFFER(br-lan) 192.168.8.217 68:5b:35:a3:e0:54
Sat Nov 6 00:31:48 2021 daemon.info dnsmasq[2543]: read /etc/hosts - 4 addresses
Sat Nov 6 00:31:48 2021 daemon.info dnsmasq[2543]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sat Nov 6 00:31:48 2021 daemon.info dnsmasq-dhcp[2543]: read /etc/ethers - 0 addresses
Sat Nov 6 00:31:48 2021 kern.info kernel: [ 23.365586] usbcore: registered new interface driver rtl8821au
Sat Nov 6 00:31:49 2021 daemon.info dnsmasq-dhcp[2543]: DHCPREQUEST(br-lan) 192.168.8.217 68:5b:35:a3:e0:54
Sat Nov 6 00:31:49 2021 daemon.info dnsmasq-dhcp[2543]: DHCPACK(br-lan) 192.168.8.217 68:5b:35:a3:e0:54 family-iMac
Sat Nov 6 00:31:50 2021 daemon.notice procd: /etc/rc.d/S99gl_mv1000_wifi: ls: /sys/devices/platform/soc/soc:internal-regs@d0000000/d005e000.usb/usb1/1-1/1-1.1/1-1.1:1.0/ieee80211/phy*/device/: No such file or directory
Sat Nov 6 00:31:50 2021 daemon.notice procd: /etc/rc.d/S99gl_mv1000_wifi: ls: /sys/devices/platform/soc/soc:internal-regs@d0000000/d005e000.usb/usb1/1-1/1-1.1/1-1.1:1.2/ieee80211/phy*/device/: No such file or directory
Sat Nov 6 00:31:50 2021 daemon.notice procd: /etc/rc.d/S99gl_mv1000_wifi: ls: /sys/devices/platform/soc/soc:internal-regs@d0000000/d005e000.usb/usb1/1-1/1-1:1.0/ieee80211/phy*/device/: No such file or directory
Sat Nov 6 00:31:50 2021 daemon.notice procd: /etc/rc.d/S99gl_mv1000_wifi: ls: /sys/devices/platform/soc/soc:internal-regs@d0000000/d005e000.usb/usb1/1-1/1-1:1.2/ieee80211/phy*/device/: No such file or directory
Sat Nov 6 00:31:50 2021 daemon.notice procd: /etc/rc.d/S99gl_mv1000_wifi: ls: /sys/devices/platform/soc/soc:internal-regs@d0000000/d005e000.usb/usb1/1-1/1-1.2/1-1.2:1.0/ieee80211/phy*/device/: No such file or directory
Sat Nov 6 00:31:50 2021 daemon.notice netifd: wan (2965): udhcpc: sending discover
Sat Nov 6 00:31:50 2021 kern.info kernel: [ 25.735486] EXT4-fs (mmcblk0p3): recovery complete
Sat Nov 6 00:31:50 2021 kern.info kernel: [ 25.740720] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
Sat Nov 6 00:31:51 2021 daemon.notice netifd: Network device ‘wan’ link is down
Sat Nov 6 00:31:51 2021 daemon.notice netifd: Interface ‘wan’ has link connectivity loss
Sat Nov 6 00:31:51 2021 kern.info kernel: [ 26.700113] mv88e6085 d0032004.mdio-mii:01 wan: Link is Down
Sat Nov 6 00:31:51 2021 daemon.notice netifd: wan (2965): udhcpc: received SIGTERM
Sat Nov 6 00:31:51 2021 daemon.notice netifd: Interface ‘wan’ is now down
Sat Nov 6 00:31:51 2021 daemon.notice netifd: Interface ‘wan’ is disabled
Sat Nov 6 00:31:51 2021 daemon.notice netifd: Interface ‘wan’ is enabled
Sat Nov 6 00:31:51 2021 kern.info kernel: [ 26.828129] IPv6: ADDRCONF(NETDEV_UP): wan: link is not ready
Sat Nov 6 00:31:51 2021 daemon.info dnsmasq[2543]: exiting on receipt of SIGTERM
Sat Nov 6 00:31:51 2021 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Sat Nov 6 00:31:51 2021 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Sat Nov 6 00:31:52 2021 daemon.info dnsmasq[3532]: started, version 2.80 cachesize 150
Sat Nov 6 00:31:52 2021 daemon.info dnsmasq[3532]: DNS service limited to local subnets
Sat Nov 6 00:31:52 2021 daemon.info dnsmasq[3532]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth nettlehash DNSSEC no-ID loop-detect inotify dumpfile
Sat Nov 6 00:31:52 2021 daemon.info dnsmasq-dhcp[3532]: DHCP, IP range 192.168.8.100 – 192.168.8.249, lease time 12h
Sat Nov 6 00:31:52 2021 daemon.info dnsmasq[3532]: using local addresses only for domain test
Sat Nov 6 00:31:52 2021 daemon.info dnsmasq[3532]: using local addresses only for domain onion
Sat Nov 6 00:31:52 2021 daemon.info dnsmasq[3532]: using local addresses only for domain localhost
Sat Nov 6 00:31:52 2021 daemon.info dnsmasq[3532]: using local addresses only for domain invalid
Sat Nov 6 00:31:52 2021 daemon.info dnsmasq[3532]: using local addresses only for domain bind
Sat Nov 6 00:31:52 2021 daemon.info dnsmasq[3532]: using local addresses only for domain lan
Sat Nov 6 00:31:52 2021 daemon.warn dnsmasq[3532]: no servers found in /tmp/resolv.conf.auto, will retry
Sat Nov 6 00:31:52 2021 daemon.info dnsmasq[3532]: read /etc/hosts - 4 addresses
Sat Nov 6 00:31:52 2021 daemon.info dnsmasq[3532]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sat Nov 6 00:31:52 2021 daemon.info dnsmasq-dhcp[3532]: read /etc/ethers - 0 addresses
Sat Nov 6 00:31:53 2021 kern.info kernel: [ 28.932542] mv88e6085 d0032004.mdio-mii:01 wan: Link is Up - 1Gbps/Full - flow control rx/tx
Sat Nov 6 00:31:53 2021 kern.info kernel: [ 28.942002] IPv6: ADDRCONF(NETDEV_CHANGE): wan: link becomes ready
Sat Nov 6 00:31:53 2021 daemon.notice netifd: Network device ‘wan’ link is up
Sat Nov 6 00:31:53 2021 daemon.notice netifd: Interface ‘wan’ has link connectivity
Sat Nov 6 00:31:53 2021 daemon.notice netifd: Interface ‘wan’ is setting up now
Sat Nov 6 00:31:53 2021 daemon.notice netifd: wan (3741): udhcpc: started, v1.30.1
Sat Nov 6 00:31:53 2021 daemon.notice netifd: wan (3741): udhcpc: sending discover
Sat Nov 6 00:31:55 2021 daemon.notice procd: /etc/rc.d/S99gl_route_policy: uci: Entry not found
Sat Nov 6 00:31:55 2021 daemon.notice procd: /etc/rc.d/S99gl_tertf: killall: gltraffic: no process killed
Sat Nov 6 00:31:56 2021 user.notice wireguard: wireguard client start
Sat Nov 6 00:31:56 2021 daemon.info procd: - init complete -
Sat Nov 6 00:31:57 2021 daemon.notice netifd: wan (3741): udhcpc: sending discover
Sat Nov 6 00:32:00 2021 daemon.notice netifd: wan (3741): udhcpc: sending discover
Sat Nov 6 00:32:34 2021 daemon.notice netifd: wan (3741): udhcpc: sending select for 64.99.227.134
Sat Nov 6 00:32:34 2021 daemon.notice netifd: wan (3741): udhcpc: lease of 64.99.227.134 obtained, lease time 28800
Sat Nov 6 00:32:34 2021 daemon.notice netifd: Interface ‘wan’ is now up
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[3532]: reading /tmp/resolv.conf.auto
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[3532]: using local addresses only for domain test
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[3532]: using local addresses only for domain onion
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[3532]: using local addresses only for domain localhost
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[3532]: using local addresses only for domain invalid
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[3532]: using local addresses only for domain bind
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[3532]: using local addresses only for domain lan
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[3532]: using nameserver 216.30.180.21#53
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[3532]: using nameserver 216.30.180.22#53
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[3532]: exiting on receipt of SIGTERM
Sat Nov 6 00:32:34 2021 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Sat Nov 6 00:32:34 2021 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[5501]: started, version 2.80 cachesize 150
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[5501]: DNS service limited to local subnets
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[5501]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth nettlehash DNSSEC no-ID loop-detect inotify dumpfile
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq-dhcp[5501]: DHCP, IP range 192.168.8.100 – 192.168.8.249, lease time 12h
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[5501]: using local addresses only for domain test
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[5501]: using local addresses only for domain onion
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[5501]: using local addresses only for domain localhost
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[5501]: using local addresses only for domain invalid
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[5501]: using local addresses only for domain bind
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[5501]: using local addresses only for domain lan
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[5501]: reading /tmp/resolv.conf.auto
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[5501]: using nameserver 216.30.180.21#53
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[5501]: using nameserver 216.30.180.22#53
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[5501]: read /etc/hosts - 4 addresses
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq[5501]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sat Nov 6 00:32:34 2021 daemon.info dnsmasq-dhcp[5501]: read /etc/ethers - 0 addresses
Sat Nov 6 00:32:36 2021 user.notice firewall: Reloading firewall due to ifup of wan (wan)
Sat Nov 6 14:11:12 2021 daemon.notice netifd: wan (3741): udhcpc: sending renew to 216.30.180.81
Sat Nov 6 14:11:12 2021 daemon.notice netifd: wan (3741): udhcpc: received SIGTERM
Sat Nov 6 14:11:12 2021 daemon.notice netifd: Interface ‘wan’ is now down
Sat Nov 6 14:11:12 2021 daemon.notice netifd: Interface ‘wan’ is disabled
Sat Nov 6 14:11:12 2021 daemon.notice netifd: Interface ‘wan’ is enabled
Sat Nov 6 14:11:12 2021 daemon.notice netifd: Interface ‘wan’ is setting up now
Sat Nov 6 14:11:12 2021 daemon.warn dnsmasq[5501]: no servers found in /tmp/resolv.conf.auto, will retry
Sat Nov 6 14:11:12 2021 daemon.notice netifd: wan (14257): udhcpc: started, v1.30.1
Sat Nov 6 14:11:12 2021 daemon.notice netifd: wan (14257): udhcpc: sending discover
Sat Nov 6 14:11:12 2021 daemon.notice netifd: wan (14257): udhcpc: sending select for 64.99.227.134
Sat Nov 6 14:11:12 2021 daemon.notice netifd: wan (14257): udhcpc: lease of 64.99.227.134 obtained, lease time 28800
Sat Nov 6 14:11:12 2021 daemon.notice netifd: Interface ‘wan’ is now up
Sat Nov 6 14:11:12 2021 daemon.info dnsmasq[5501]: reading /tmp/resolv.conf.auto
Sat Nov 6 14:11:12 2021 daemon.info dnsmasq[5501]: using local addresses only for domain test
Sat Nov 6 14:11:12 2021 daemon.info dnsmasq[5501]: using local addresses only for domain onion
Sat Nov 6 14:11:12 2021 daemon.info dnsmasq[5501]: using local addresses only for domain localhost
Sat Nov 6 14:11:12 2021 daemon.info dnsmasq[5501]: using local addresses only for domain invalid
Sat Nov 6 14:11:12 2021 daemon.info dnsmasq[5501]: using local addresses only for domain bind
Sat Nov 6 14:11:12 2021 daemon.info dnsmasq[5501]: using local addresses only for domain lan
Sat Nov 6 14:11:12 2021 daemon.info dnsmasq[5501]: using nameserver 216.30.180.21#53
Sat Nov 6 14:11:12 2021 daemon.info dnsmasq[5501]: using nameserver 216.30.180.22#53
Sat Nov 6 14:11:15 2021 user.info mwan3rtmon[2267]: Detect rtchange event.
Sat Nov 6 14:11:15 2021 user.notice firewall: Reloading firewall due to ifup of wan (wan)
I didn’t change the time. I had the unit powered off (since it was breaking things) so perhaps I accidentally grabbed some of the syslog entries from the prior run. I can confirm that on the GL-MV1000 that it gets the same IP address and DNS info over DHCP as I see on my Netgear Orbi when it is in router mode. This picks up Ethernet over a basic Adtran from Ting to convert fiber to Ethernet. I’ve opened a support ticket with them as well in case they have any ideas.
I tried a factory reset in hopes that this would resolve it, but the same thing is happening. I’m trying to reach their support group to see if there any other ideas.
I worked with the support group and we found the solution. I clones the MAC address of my Netgear Orbi router/mesh wifi system onto the GL router and then it worked consistently fine.
In this case, if you do not use mac clone, you may try reboot your ISP router/modem. If you just got a cable with DHCP, you may call ISP to asking them to reset their machine for you.
Further note on the solution here. The MAC clone worked for about 48 hours. I called my provider (Ting) and they needed to clear the MAC address of the previous router. Once that was done the GL.inet router works wonderfully. I hope this explanation helps anyone else who encounters this issue.
