Hallo. I have a question. I have pc card only with one DVI-I DUAL LINK. Can I use spliter from one DVI-I to two DVI-I and later converter from DVI-I to HDMI and connect this cable to GL-RM1 ? Somebody try this configuration?
I don't find anyone who try this setup from spliter to adapter to kvm.
This configuration is theoretically feasible, but not recommended.
Because of the signal link is too long and DAC compatibility unknown.
If you wanna try, buy an active DVI to Hdmi adapter is a better choice.
