I just got my GL-RM1 with the ATX board, hooked everything up and it seems the power buttons in the UI do not function. The physical power button does work as a pass through however. Anyone know what might be wrong?
I also noticed that the provided cable the polarity on the reset switch is backwards and the red wire is actually the ground, but I don't think that matters for the reset switch, and the reset switch does work in the UI.
