GL-RM1 audio not working
I cant get audio remotely. Is there anything I'm missing? I know there's a button to unmute and did try that.
Please note that some HDMI adapters will remove the audio signal.
In addition, please check whether GLKVM is set as the primary audio output on your controlled computer.
You can check the audio output settings on the controlled computer and check whether it is set to mute.
I tried on a different pc and audio does work. The problem seems to be that the hdmi audio drivers isn't installed. Is there a driver for the hdmi audio I can install manually?
looks like it may be EDID issue? when I set it to 2560x1440/GLKVM/60HZ no audio comes in but when I change to 3840x2160/GLKVM/30HZ sound does come in.
Different EDIDs may require different driver support. You can scan the driver or try Windows troubleshooting.
try below edid:
00 ff ff ff ff ff ff 00 5a 63 34 2f ea 50 00 00
24 1e 01 03 80 35 1e 78 2e ff d5 a9 53 45 a0 25
0d 50 54 bf ef 80 d1 c0 b3 00 a9 40 a9 c0 95 00
90 40 81 80 81 c0 56 5e 00 a0 a0 a0 29 50 30 20
35 00 0f 28 21 00 00 1a 00 00 00 fd 00 32 4c 1e
53 1e 00 0a 20 20 20 20 20 20 00 00 00 fc 00 56
58 32 34 37 38 2d 32 0a 20 20 20 20 00 00 00 ff
00 55 59 4c 32 30 33 36 32 30 37 31 34 0a 01 ea
02 03 24 f1 4f 90 05 04 03 02 07 12 13 14 16 1f
20 21 22 01 23 09 7f 07 83 01 00 00 67 03 0c 00
10 00 20 40 02 3a 80 18 71 38 2d 40 58 2c 45 00
0f 28 21 00 00 1e 01 1d 80 18 71 1c 16 20 58 2c
25 00 0f 28 21 00 00 9e 01 1d 00 72 51 d0 1e 20
6e 28 55 00 0f 28 21 00 00 1e 02 3a 80 d0 72 38
2d 40 10 2c 45 80 0f 28 21 00 00 1e 01 1d 80 d0
72 1c 16 20 10 2c 25 80 0f 28 21 00 00 9e 00 50
That works.
this is what i have for edid
I am just getting my Comet setup, and the only audio that seems to work is the
I think, that it is the 30HZ portion that enables the Intel Audio from the Host B device.
Any assistance would be greatly appreciated
Do you in v1.1.1 release1? There is no reason that GLKVM 2K has no sound while AOC 2K does, because they should essentially be the same thing in v1.1.1 release1
yup i have the latest version.
We have released the latest version of the test firmware 1.2.1 on discord. It should have solved the problem. You can give it a try
How do i Join the discord Group? is there a list of fixes/Improvments on the version?
upgraded and now sound comes in on that setting.
i did have a small issue, when i upgraded from the app, after 30 minutes, it just hangs at "upgrading..". I just use the web interface and reboot it the device and appears to be working now.
What is with that dicord thing? What about those who do not have acces to it??
Don't worry, the firmware will be pushed to everyone eventually, we are just testing it on a small scale in discord
another place we comunicate with you guys,here is the invite link: GL.iNet
Here is the invite link:GL.iNet
