Hello. I just recieved Gl-RM1 and played with it today. I've been using PiKvm for a long time for my work and noticed a thing that does not work for me with Gl-RM1. In full screen mode, ESC is configured to exist the full screen mode (which PiKvm does not). This beomes annoying as I frequently uses ESC for my work and I have to switch it back. I did not find a way to workaround exit full screen mode by ESC key. I wonder if it can be implemented to configure or disable the key to exist the full screen mode. Thanks.
We will optimize it in future versions
Are you using the GLKVM software? The ESC key does not exit fullscreen mode on MacOS. I can't say for Windows
