GL-RM1 (Comet) ChromeOS compatibility
I see the Comet is now available for preorder and I have been looking into getting one. I see there is an app for both Windows and macOS for remote control. Will there be an option to connect to the Comet from ChromeOS or from Linux? If that is an option I will for sure order multiple units.
Currently there is no control software for Chrome OS or Linux.
We will develop Linux software in later stage.
Thank you.
Also an android would help maybe?
Android version is still under development
Thank you. Maybe I should buy it?
Is an iOS app in development as well? And one feature I would love to see is the option to connect to 2 devices at once and display them side by side or with the option to swap displays, for example if I connect 2 comets to the same PC (which I will definitely do for a few of my clients)
any ETA?
Buying Comet for use with a Galaxy Tab S10+.
Comet (GL-RM1) - GL.iNet You can pre-order it here.
have ordered but will it work using galaxy tab s10+ as a client device for controlling my windows or linux machine?
is the android client software soon to be released?
An Android version is already in development, but it will take some time
You can configure tailscale and access comet through the browser
Tailscale on router with a few settings is a pretty good way to tunnel to lan.
For a beta feature it seems to work well
@robotluo Is there a help document that explains how to access comet through the browser remotely using any controlling device - android. iOS or iPadOS?
is there a help document that explains how to do that?
It is really easy nut absolutely useless if you want to use the touchscreen on your phone as mouse configuration and all other controls are not suitable for touchscreen devices.
You can use tailscale+chrome for remote access on mobile devices
It has been answered a few times now, but I use tailscale + the IP web page.
Works identically to the GLiNET RM app. Better actually since it automatically saves and enters the password for the GL-RM1.
