system_logs_20260330_134141.zip (48.7 KB)
Hello, my KVM goes offline after the firmware update beyond version 1.7.2. I have tested all firmware versions newer than 1.7.2.
thank you in advanced
Could you try running this command to see if it helps resolve the issue?
jq '. + {"keepalive": 90}' /etc/glinet/gl-cloud.conf > /tmp/gl-cloud.conf; mv /tmp/gl-cloud.conf /etc/glinet/gl-cloud.conf; /etc/init.d/S99gl-cloud restart
