As an experiment you may want to try disabling any USB functionality like virtual media or cameras. The BIOS may not be able to accept complex composite devices and is expecting a very basic keyboard/mouse device.
It's a troubleshooting step more than anything else. Personally I've been pushing for a "dumb mode" switch in the UI since those features don't work with my subtending KVM switch. In the rare instances you need to access the BIOS, flipping that toggle prior to reboot doesn't lose you anything (BIOS doesn't recognize the storage anyway) and you can re-enable it once you're done. If you need to boot off the virtual media it does become more of an annoyance depending on your BIOS versioning. Normally I can access the BIOS screen with virtual media enabled, but I do have one PC where I'm probably experiencing the same issue as you. Since I rarely need to change BIOS settings (and never remotely) I just direct connect a keyboard to access it. It may be worth looking into your exact model to see if there's a BIOS upgrade that may be better behaved.
i totally agree with you and yes to confirm it works on loading screen with disabling virtual media on kvm but not with bios or boot menu, but woundering how we can use both at the same time right?
Great! It sounds like the issue I have on one of my mini PCs (on my full desktops I can get into BIOS with Virtual Media enabled). For the initial setup I worked around it by attaching a physical keyboard to the computer and using that to change the boot order to the virtual media drive. Since I rarely need to enter BIOS that works fine and I just need to remember to disable virtual media if I need to make a tweak. In steady state I don't mind not having keyboard input at the BIOS layer, but if you've got a bootup password that makes things more annoying. You may have to disable virtual media on bootup, then re-enable it once the OS boots (or at least once you've entered the password). Most operating systems don't mind the USB change. Does your workflow need a BIOS keyboard often or is it like mine where it's mostly once-and-done annoyances?
It's possible your HP has a BIOS update that handles complex composite devices better, but I wasn't able to find one for my generic-brand MiniPC.
This might be related to an issue on HP's part, such as a BIOS compatibility issue. You might want to check with HP to see if they have any information on this.
