GL-RM1 upgraded to V1.9.0 release1. Keeps cycling
Just got it out of the box a few weeks ago - no VPN nothing else is installed or configured. Only power and ethernet is connected.
Downgraded back to 1.8.2 - same issue.
Downgraded all the way to 1.3.1 - same issue.
Did reset and hard reset, changed power supply and cables - same issue.
Downloaded the logs from 1.3.1 attached to this message.
Trying to upgrade back to 1.9.0 again - its kinda stuck on download progress.
system_logs_20260430_140545.zip (46.7 KB)
if you are having this issue on multiple sets of firmware I would say just open an exchange
wget https://fw.gl-inet.com/kvm/rm1/release/glkvm-RM1-1.9.0-0427-1777284262.img -O /userdata/update.img  && updateEngine --image_url=/userdata/update.img --misc=update --savepath=/userdata/update.img --n --keep_config --reboot`
run this command to upgrade
