I was messing around with the comet on an existing non-ip based KVM.
IT works great if I plug it into the USB Device sharing port, but will not work if I plug it into the keyboard or mouse port.
I know it's a crazy idea, but I thought I would give it a shot.. Any thoughts on if it's possible?
That is a very good question, I will have to dig a bit and see..
Everything works okay in what I'll call default mode (No override.yaml changes) if I plug the Comet into the USB sharing port. I can then control the computer no issues, if I power on with them in the keyboard even under windows it does not seem to work.
I change the override.yaml and everything works perfectly in the keyboard usb port including switching between devices.
IT works applying the override in the override.yaml, I'm a happy camper! The Comet is a perfect friend and helper,
Yes once I changed the device type to the 'Corsair Gaming RGB', I was able to use the hotkey functions. Otherwise it would not work with the USB keyboard port only the USB Sharing port.
I have a comet RM1 connected to my Trendnet 1603R non IP KVM and it works beautifully!! I have access to all my servers from one device !! Thank you GL-iNet.
For those of you like me who have a KVM with a VGA output I purchased the BENFEI VGA to HDMI Adapter, 1080P Converter with Audio from Computer/Laptop VGA Source to HDMI TV/Monitor cable. This was the only one that work out of the few I tried.
