Hi, I’m wondering if the Comet Pro will support MacBook Neo. It does Alt DP mode with its USB-C, but has no HDMI port. Thanks.
Hi, you can use a USB-C hub with your MacBook Neo, then connect an HDMI cable to the Comet Pro's HD IN port.
