GL-RM10 Comet Pro keyboard/mouse not working correctly with Framework Desktop in BIOS/Ventoy/Proxmox
I'm having some strange USB HID issues using a new GL.iNet GL-RM10 Comet Pro with a new Framework Desktop
Video works perfectly, but keyboard and mouse control are unreliable. I checked other posts and nobody seems to have it as specific as mine, I’ve turned my KVM to only use mouse (2 resources) and keyboard (1 resource) for a total of 3/10 resources.
The mouse works for the most part int he BIOS, except for the bottom menu of the bios highlighted here in red
Sometimes its misaligned with the clicks some buttons are inaccessible like Save and Exit.
I tested with a directly mouse connected to the pc and works fine.
Also the keyboard is 99% a miss, ctrl l + alt l + del works (thank goodness) and F2 works to get into the bios, after that doesn’t respond. (doesn’t respond inside grub/ Ventoy boot either). I couldn’t get any keys to work, especially not F10 which is Save and Exit.
I tested with a directly keyboard connected to the pc and works fine.
this is all usb-c to usb-c (all from the box) i couldn’t get any combination of C to A or A to C to work even when rebooting in between.
I tried both Absolute and Relative mouse modes.
  1. I tried Adaptive and Original Pixel view modes.
  2. I tried Bad Link Mode.
  3. I'm accessing the RM10 web interface using Chrome.
  4. RM10 firmware is V1.10.0 release3.
  5. Video is being captured at 1920x1080 over WebRTC.
The strange part is that F2 (both virtual keyboard and physical) and Ctrl+Alt+Del work, so the Framework is clearly receiving some keyboard events from the RM10, but normal HID keyboard input doesn't seem to work once I reach BIOS menus, grub, Ventoy, or the Proxmox bootloader.
Has anyone encountered this with the Framework Desktop or another Insyde UEFI system?
Being able to control BIOS/bootloaders remotely is one of my primary reasons for using the KVM. I could have saved myself the past 2 hours by plugging a keyboard and mouse directly into the machine instead of trying to beat this thing into submission.
The mouse misalignment issue is caused by you providing a 1080P EDID while the display is not in that aspect ratio. You can switch to a 4:3 EDID, which should fix the alignment.
Thanks that helped for the mouse with the main BIOS.**
The keyboard issues are now very reproducible: the Desktop receives F2 from the RM10 during POST, including a Raw F2 right from the console via the following commands
printf '\x00\x00\x3b\x00\x00\x00\x00\x00' > /dev/hidg0
printf '\x00\x00\x00\x00\x00\x00\x00\x00' > /dev/hidg0
Raw F2 during boot via the console commands works and successfully enters the BIOS pre-boot menu.
This rules out issues from the Browser (Chrome & Opera), WebRTC, the RM10 virtual keyboard, and normal KVMD keyboard handling.
So i have Ctrl + Alt + Del works anytime. and F2 during POST, anything other keyboard input does not make it through.
I’ve tried everything. USBC-C and USBA→C USBC→A (ctrl alt del works every time within these trials so i know it’s plugged in correctly) I even put a dumb USBA hub in between to try to step it down from full-speed to high-speed.
A physical USB keyboard plugged directly into the PC works normally.
Plugging the USBC from the RM10 into my phone allows me to type into it so keyboard can work from RM10.
I’m baffled at what’s going on.
Same issue with the keyboard here, did you figure it out, @xphacter ?
Hi, could you please share a few more details about the issue?
  • Are you also using a Framework Desktop?
  • Does the keyboard issue only occur during the BIOS stage, or does it also occur after entering the operating system?
  • If possible, please try a different USB-C cable.
  • Are you connecting the peripherals directly to the KVM's USB port or through an external USB hub?
If the issue persists, please export the syslog and share it with us via PM.
I give you a test firmware, see if it work
Thanks for replying so quickly. I installed glkvm-RM10-1.10.0-0904-1788488960.img, but unfortunately the keyboard behavior is unchanged.
Steps to reproduce:
  1. Connect the Comet Pro GL-RM10 to a Framework Desktop running BIOS 03.06.
  2. Reboot the Framework.
  3. Send F2 or F12 through Comet during POST.
  4. The Framework opens BIOS Setup or the F12 boot menu.
  5. Try navigating with either the client’s physical keyboard or Comet’s on-screen virtual keyboard.
  6. No keyboard input is accepted anywhere on the screen.
Video and mouse continue working. A USB keyboard connected directly to the Framework works normally, and Comet keyboard input works again at the LUKS prompt and in Linux.
I also tested with virtual media disabled, cycled the emulated keyboard, tried all available USB identity presets, and rebooted both devices.
I’m happy to provide a syslog captured after reproducing the problem if that would help.
Thanks again for investigating this.
Thanks! I’ve given a more details in a standalone message, here are the answers to your specific questions.
  • Yes
  • Only BIOS
  • I tried with the provided ones. Keyboard works normally outside of BIOS. But ti can try diffent usb cables.
  • No periferals connected to the KVM. I’m accessing the Comet web console from Google Chrome on macOS over Tailscale, using WebRTC H.264 in P2P mode.
Well, I don't have much of a solution left. In fact, as we previously tested with certain OEM-customized BIOSes, it's simply impossible to control their BIOS. For example, take HP's BIOS.
Your last resort might be to disable all other devices in the device manager and keep only the keyboard – see if it works. If that doesn't work either, then there's no saving it.
@magoz your repro matches mine exactly, thanks for posting it, good to know it isn't just my unit.
I was not able to fix it, in the end i just used a different KVM solution. We have about 3 remote Framework Desktops and would rather not play around in case of an emergency.
the failure window is very replicatable:
  • POST hotkeys work (F2, F12, Ctrl+Alt+Del)
  • anything using UEFI Console Input is dead
  • Linux/Windows is fine
The RM10 is emitting valid boot-protocol reports (my raw /dev/hidg0 F2 test showed that) and the Framework consumes them at both ends of the boot.
On disabling other devices - I'm already down to 1/10 resources, keyboard only, and it makes no difference.
This Framework takes a plain USB keyboard in Setup with no trouble, so its UEFI isn't refusing USB HID in general, it's refusing this particular gadget. That's usually a descriptor or control-transfer detail, not a locked down BIOS. I even got a PS/2 keyboard through a usb adapter to work with the Framework BIOS aka InsydeH2O. I'm pretty sure InsydeH2O is very common bios, i've seen it on many different laptops. I could go and complain to Framework but they will just say the same thing GLiNet is saying "we can't test everything on the planet" and they arent wrong.
thanks for your reply! Yeah it seems that our our cases match exacly.
What KVM did you end up going with?
Out of respect for not naming competitors on a support form. I'm just going to go say it's a rack-mounted 8-port KVM over IP. We are still going to use the glinet finger bot though for remote forced reboot if needed.
Thank you!
I just got my Comet X yesterday and I can confirm the exact same behavior as you have described above when connected to an HP Elite Mini 600 G9 Desktop PC. The HP is running the 02.23.00, 7/27/2026 BIOS. Comet is running V1.10.1 release3 (RM4PE). It is working fine on a Lenovo ThinkCentre M75q Gen2, and a Dell OptiPlex Micro 7010.
I can hit F10 to get into the BIOS, but once there, no keyboard.
The keyboard that is plugged into the Comet works fine.
I have tried all of the prelisted keyboards (GLKVM Default, Corsair Gaming RGB, Dell Multimedia Pro Keyboard, Microsoft Pro Multimedia Keyboard, Logitech Unifying Receiver for Keybo...) without any luck.
Could you try using the virtual keyboard and see if it works in the BIOS?
Definitely 100% does not work.
I've spent hours trying all sorts of things.
Like I said I even had to resort to sending direct key commands via the console through /dev/hidg0
I'm able to fully control the PC in other areas with the RM10, the moment I'm in the BIOS nothing works.(Except for trying other physical keyboards directly connected to the machine but that defeats the point)
Virtual keyboard works outside the BIOS just fine.
Have you tried connecting the RM10 to a usb 2.0 port?
Maybe the bios has issues with usb 3+ or: the RM10 is forcing usb3 rather than negotiating to usb 2.0 speed.
I had to check this myself but the keyboard works with usb c, but if comet pro forces usb 3.0 hence it must run under 2.0 speed due to the bios settings it breaks, maybe it is a legacy thing by the bios.
Using usb c to usb-A adapter can help debugging it more.
Yes I tried all that. I have two posts from August 16th that explain everything that I did. I apologize they are walls of texts. However both of them mentioned the Virtual keyboard and stepping down from full speed USB to high speed. I used a dumb USB hub to force the step down. I even double checked these speeds on the console.
I've literally exhausted every avenue and spent days with this device short of writing some sort of firmware or drivers.
The issue will come up more often with people who try to use the GL-RM10 with a Framework or HPE Laptops which come with InsydeH2O bios. I don't know if the BIOS needs an update or what. But the BIOS has taken every keyboard (usb-c/a ps/2) including other KVMs and worked.
Yea-I have also tried the virtual keyboard without any luck. I tested my other IP-KVM (not to name it but rhymes with set) and it works fine with the USB and HDMI plugged into the same ports.
I am observing the same.
Using a GL-RM1PE with a Framework Desktop running BIOS 03.06.
The Comet I received was initially running FW 1.7.1 - with this the keyboard did work at the BIOS!
It only broke in the way described by others in this thread when upgrading to 1.10.1.
I was able to downgrade to 1.9.1 and have it still work to use the keyboard in the BIOS.
I hope this is useful information to identify what is the cause of this and also can be a workaround for others that need to interact with this BIOS.
