My GL-RM10 (Comet Pro) is a few days old. It lost its Wi-Fi connection after a short router event and did not reconnect. It stayed offline for about 25 hours, until I power-cycled it.
Setup
- Device: GL-RM10, firmware V1.10.1 release2 when the fault happened. I have since updated to V1.10.3 release1.
- Note: I chose to keep settings during the update, but the update still reset the EDID setting from 1920x1080@60 to the default 1280x720 profile.
- Connection: Wi-Fi (the RM10 has no Ethernet port), 5 GHz, channel 36, 40 MHz, signal about -41 dBm
- Router: Sky ISP router, DHCP, IPv4 and IPv6
- Remote access: Tailscale
- Controlled PC: Linux desktop, RM10 on HDMI and USB
What happened (times are UTC)
- 23 Nov, 04:56: Tailscale last saw the RM10.
- About 04:57: the internet connection dropped for about 1 minute. My desktop logged failed uploads during that minute.
- 04:58: the router announced a new IPv6 prefix. This suggests a WAN reconnect on the router.
- My desktop is on the same router over Wi-Fi. It stayed connected and recovered by itself.
- The RM10 did not recover. It did not answer on the LAN or on Tailscale. The touchscreen showed "no network".
- The RM10 itself kept running. Its USB keyboard and mouse stayed connected to the PC, and the HDMI link stayed up.
- 24 Nov, about 05:41: I power-cycled the RM10. It was back on the LAN at once, and on Tailscale after about 50 seconds.
Logs
I exported the logs after the power cycle, so they only cover the new boot. The RM10 keeps its log in RAM only, and /userdata/log/last_boot.log does not exist. I can send the zip by private message.
Related threads
This looks like the same problem as these threads:
- RM10 Wi-Fi fails to reconnect after daily router reboot (71508)
- RM10 won't reconnect the WiFi (68587)
Thread 71610 says V1.10.1 release2 fixed a similar problem. My unit failed on V1.10.1 release2.
Questions
- Is this a known fault? Does V1.10.3 release1 fix it?
- Is there a setting to keep logs across reboots? Then I can send you logs that cover the fault next time.
- The RM10 is Wi-Fi only. Do you recommend a static IP, or any router or Wi-Fi settings, to avoid this problem?
- I plan to run the RM10 unattended at a remote site for long periods. Nobody there can power-cycle it. What setup do you recommend for this use? Is there a built-in watchdog that restarts the network when the gateway is unreachable for a long time?
I will report back if the problem happens again on V1.10.3 release1.
Thank you,
Gregor
