I purchased a PoE Comet when it came out and I recently noticed that on my Unraid server, it is showing up as a USB device. When I was using the original Comet, it didn’t behave like that unless it was mounted. I do not have the USB device mounted but I can’t seem to fix it. Could someone please provide some guidance to help fix this. Thank you in advance!
Comet will indeed appear as a USB drive on the controlled device. If it is not mounted, the USB drive will be inaccessible. The only way to prevent it from being displayed is to disable virtual media.
