Date on the kvm is Jan 1 1970, even after reboot. That seems to mess with tailscale. Do you know how to fix it?
gl-rm1pe 1.9.1.release1
1.10.1 Beta test firmware for RM1V2/RM1PE/RM10RC/RM4PE - KVM - GL.iNet Official Forum
Try this beta firmware, see if it make any improvement
Thanks for the quick support!
Today I checked the date and it was ok
maybe it was a temporary issue. I will upgrade to 1.10 when it becomes official for the rm1pe. Is there an ETA?
maybe today
Came here looking for information on the same issue.
The front display gives date time in 1970.
I see the settings on the device gives a setting for timezone, but nothing for an NTP server config, or manual way to set a clock.
Is it trying to use a hardcoded NTP server? Is it trying to get one via DHCP?
Hi, what firmware version are you using? The time is obtained through DHCP.
I am running V1.10.1 release3.
I also double checked my router and it should be handing out NTP settings via DHCP.
But I specifically updated the DHCP reservation with the NTP settings as well, and it now shows the correct date & time on the front.
So if anyone else reads this, check your general DHCP NTP settings, and maybe add it to any specific DHCP reservation too.
