GL-RM1PE vs GL-RM1
When I was comparing the GL-RM1PE & GL-RM1 KVMs, I asked a couple of questions about the ability to stream audio. It was not available on either. I was told it was getting added to both. I know it has been added to the GL-RM1. When will they add the streaming to the GL-RM1PE??
From my understanding, they are pretty much the same device, but one has POE. It has been quite a while since they updated the GL-RM1.
Did I waste my $$ on the GL-RM1PE?
I strongly recommend you buy the RM1PE; it will only have more features than the RM1, both in terms of hardware and software. The performance is also better.
I figured out the issue. I do have the GL-RM1PE. I had to cycle the power to get it to address the one device. Other than that, everything works as it should.
