Hey GL.iNet forum!
I’ve updated the firmware of my GL-S10 to gl-s10-aws-factory-3.0.3.bin. My hardware revision is GL-S10_V1.0. After switching to the AWS firmware, my device is stuck in crash & restart loop. It never turns on and crashes after giving this error:
file: "../components/gl_dev_network/src/gl_dev_network.c" line 93
func: gl_install_eth
expression: esp_eth_driver_install(&config, ð_handle)
abort() was called at PC 0x40093a0b on core 0
Please check the attached full log file glinet-esp32.log.
glinet-esp32.log.zip (3.4 KB)
The device works well with the standard firmware. The issue occurs only with the “AWS” firmware. What are the differences between aws firmware and the standard-factory firmware? I’d like to connect this gateway to AWS IoT Core; so do I need the aws version? If yes, how can I fix the restart & crash loop problem?
Thanks in advance.
Emir
