I’m integrating a GL‑S10 BLE gateway (the non‑ESPHome, “capable” GL‑IoT firmware model) with my own MQTT broker.
The gateway connects correctly and publishes BLE telemetry on tiot/#. It also subscribes to GL-IoT/comTopic/<gateway-mac> as expected.
However, I cannot find any documentation describing the JSON format required for sending BLE control commands through GL-IoT/comTopic.
Could GL.iNet provide a generic example of:
A JSON command sent to
GL-IoT/comTopic/<gateway-mac> -
The corresponding JSON response published on
GL-IoT/rspTopic/<gateway-mac>
The example does not need to be device‑specific — any BLE device command/response pair would be extremely helpful.
This will allow me to understand the correct command schema and integrate the gateway properly.
Thanks
