I have a GL-S1300 as my main router and two GL-B1300’s as mesh nodes. Multiple times throughout the day the network “drops” all connections for 1-2 minutes.
Here is the Kernel Log from when it happens:
https://pastebin.com/raw/YywK20LT
Here is the System Log
https://pastebin.com/raw/AwgkmGb4
any help would be appreciated
Can you try our 3.203 firmware http://download.gl-inet.com/firmware/snapshots/20210525/
There are optimization of mesh. You need to reset each node and upgrade one by one, then mesh them up.
So I need to factory reset all three unit, apply the new firmware and then set the network up again?
Is there any way to do this without the factory reset, I’d really prefer not to have to set up the whole network again.
also that link doesn’t work
The link works, but you have “Do not use until this file is removed.txt” > “Pls do not use the firmwares in this folder until this file is removed.”
Looks like it’s still in beta. Might help (you, them, everyone else) if you have time to give them feedback.
Check your browser. The link should work.
The firmware is fine. Just not finalized.
