GL-S20 2.1.1-Release2 — OTBR REST API port 8081 refuses connections
I try to set up a Thead Network. I have no previous experience, just installed HAOS in UTM with bridget network. Ping to the GL-S20 works from Homeassistant, but trying to add it to home assistant as open thread boarder router fails on the first step.
I cannot integrate my GL-S20 Thread Border Router with Home Assistant.
  • Firmware: 2.1.1-Release2 (latest available through the web interface)
  • Firmware category: 2c
  • Initialization status: true
  • Thread network status: Leader
  • Device IP: 192.168.178.111
Symptoms:
  • The GL-S20 web interface is accessible.
  • http://192.168.178.111:8081/node returns connection refused.
  • Home Assistant cannot connect to the OTBR endpoint.
  • Using http://192.168.178.111 in the integration also fails.
Relevant log entries:
  • obtr_web: Failed to open file: /spiffs/otbr/api/actions
  • obtr_web: Failed to open file: /spiffs/otbr/node/ba-id
Thread itself reaches Leader status. The issue appears to be the OTBR REST API endpoint rather than Thread network formation.
Could you confirm whether port 8081 should be listening on the LAN interface in this firmware, and advise on a fix or recovery image if the API service is missing? (I haven’t tried wifi)
Thank you for sharing the details and logs.
Could you please refer to our GL-S20 Home Assistant setup guide and HTTP RESTful API documentation for the following checks?
  1. Please confirm that Thread Network is enabled and that the GL-S20 and Home Assistant are on the same local network.
  2. When adding the Open Thread Border Router integration, please use http://192.168.178.111:8081 as the URL.
If the connection is still refused, please share the Home Assistant integration error log via PM for us can investigate further.
Thank you for your support and understanding.
Same issue on 2.1.1-Release2: the OTBR REST API seems to be missing from the firmware, and the system log won't load
Same problem here, and I think I found the cause of the port 8081 part.
Setup
  • GL-S20, firmware 2.1.1-Release2 (gl-s20-otbr), upgraded from 2.0.1-B1 earlier this year
  • Wired WAN to the main router (192.168.1.3), with Home Assistant 2026.10.2 on the same LAN
  • Thread enabled, the S20 is Leader, and a Matter-over-Thread device works fine
  1. Port 8081 / OTBR REST API
  • http://192.168.1.3:8081/node/state → connection refused, on IPv4 and IPv6. A reboot didn't help, and neither did enabling BBR.
  • On 2.0.1-B1 this worked: Home Assistant's OTBR integration connected and imported the Thread dataset in August 2025.
  • I compared the firmware images. gl-s20-otbr-v2.0.1-B1.bin contains the OTBR REST endpoints (/node/state, /node/ba-id, /node/dataset/active, …). None of the 2.1.1-Release2 images (app, web, rcp, combine) contain them. So the REST API appears to have been removed in 2.1.1, which breaks the Home Assistant setup your guide describes.
  1. System log
  • System → Log doesn't load, and Export doesn't work either. The admin page is also generally slow.
  • The other report in this thread shows obtr_web: Failed to open file: /spiffs/otbr/.... Is the log problem a known 2.1.1 bug, or a sign of a problem with the flash storage?
Questions
  1. Was removing the REST API intentional? Wielease?
  2. Is the log page failure a known firmware issue?
  3. Is there a safe way to downgrade to 2.0.1on, without losing the Thread network(dataset/network key)?
Thanks!
Thank you for the detailed report.
  1. Currently, Home Assistant integration is only supported by the B1 firmware.
  2. You mentioned that the System → Log page and Export function are not working properly. Under what circumstances does this happen, and is it reproducible every time or only occasionally?
  3. To avoid potential issues caused by configuration incompatibility, we recommend flashing B1 without retaining the current configuration.
We apologize for the inconvenience and appreciate your patience and understanding.
Just to confirm: Open Thread Router support is only available in 2.0.1 Beta? I misread the docs here, it does say "Beta versions of v2.0.1-B1 and later", but I thought anything after v2.0.1-B1 would be fine (thus installed 2.1.1-r2)
Hi, thanks for checking.
Currently, Home Assistant integration is only supported by the special B1 firmware. Other firmware versions can still operate the Thread network and Matter-over-Thread devices normally, but do not currently support Home Assistant OTBR integration.
