GL-S20 network dataset hex
Is there a way to obtain the Thread network dataset in hex format through the GUI for this model since I cannot access using ssh.
Thanks
This may be a customized requirement.
If you are 2B customer, you can contact us by email support@gl-inet.com to evaluate this requirement with us.
Thank you, I'll contact support.
Anyway, maybe this dataset hex can be available also without customize the GUI?
I need for the commissioning using chip-tool.
Maybe it's possible, but it has to check if it has permission to read this hex data.
There is a way to ssh access to GL-20 to execute this command?
ot-ctl dataset active -x
Or obatin it through the APIs?
Thank you
Why cannot you use ssh? Can you pls explain?
Hi @alzhao,
I'm unable to access the device directly via SSH to root@device-ip.
Additionally, the GL-S20 user interface doesn't seem to have an option to enable SSH.
Am I missing something?
Thank you
Sorry I mess up with S200.
S20 is not Linux.
SSH is not supported.
There are two ways to extract:
  1. Connect to the serial port:
    dataset active -x
  2. The web source code returns content with hex data, but the WebUI doesn't show it. Read the web page source code:
Hi @bruce , thank you for your answer.
I was able to obtain the dataset hex value from the browser inspector.
Thanks
