phoebe
Following the instructions to get started and see a solid blue light initially on the router that changes to orange after a while.
No sign of it as an option to select from my wifi list on Mac or mobile phone.
Tried 10 second reset also.
Also tried mode switch in other position - what is mode?
Can anyone suggest something else to try or why it is not appearing?
Have you an Ethernet cable?
Maybe upgrading the firmware will help.
alzhao
3
This model is 2.4G wifi only. But it should appear in your wifi list.
The switch button does not matter.
phoebe
4
Yes, tried connecting via ethernet and it came up on mobile but not laptop briefly but gone again. In touch with support and will put outcome here.
Thanks.
