i want all the GL services to use VPN client connected on my flint router with Customize Routing Rules selected.
when i select the option Services from GL.iNet Use VPN under global options but still it show my router real IP not the VPN IP.
@alzhao, appreciate your usual support in this please.
Thanks in advance.
alzhao
2
Can you post details? e.g. exactly how you set up, what is the routing rules and how do you test leak.
If you don’t want post publicly you can use email.
give me some time to prepare and share it with you. thanks for your reply.
this is what i want to setup. please let me know if you need more information.
@alzhao, I send you message with all the details.
