Hello all,
I bought a new GL-SF1200-c52 and connected three PCs.
The GL-SF1200-c52 is connected to a Fritzbox, which is providing the internet connection.
I can access the subnet of the fritzbox and I can access the internet. But I can´t acces the other PCs which are connected with the switch of the GL-SF1200-c52. (The GL-SF1200-c52 replaces an older router, so it should not be an issue of the clients, because with the old router it´s working)
I checked all settings like VLAN and turned off the VLANS, but still not working.
Does anybody has an idea?
dxf
August 29, 2023, 2:55am
2
Please check the firewall of your other PCs.
I did. If I change the GL-SF1200 with the old router everything is working fine.
dxf
August 29, 2023, 7:03am
4
Can other PCs access the internet through the sf1200?
Yes. All PCs have Internet Access.
dxf
August 29, 2023, 7:20am
6
Sorry, I can’t think of any reason other than a PC firewall problem;
Can PCs ping each other?
Can you provide the configuration of /etc/config/network?
cat /etc/config/network
With old Router/Switch they can ping each other. If I replace it, they can´t.
Network config:
config interface ‘loopback’
option ifname ‘lo’
option proto ‘static’
option ipaddr ‘127.0.0.1’
option netmask ‘255.0.0.0’
config globals ‘globals’
option ula_prefix ‘fde6:c780:1d08::/48’
config interface ‘lan’
option type ‘bridge’
option netmask ‘255.255.255.0’
option ip6assign ‘60’
option hostname ‘GL-SF1200-c52’
option ipaddr ‘192.168.1.1’
option ifname ‘eth0.1’
config device ‘lan_dev’
option name ‘eth0.1’
option macaddr ‘94:83:c4:31:dc:53’
config interface ‘wan’
option ipv6 ‘0’
option metric ‘10’
option gateway ‘192.168.178.1’
option ifname ‘eth0.2’
option peerdns ‘0’
option dns ‘8.8.8.8’
option ipaddr ‘192.168.178.231’
config device ‘wan_dev’
option name ‘eth0.2’
option macaddr ‘94:83:c4:31:dc:52’
config interface ‘wan6’
option proto ‘dhcpv6’
option disabled ‘1’
config interface ‘guest’
option ifname ‘guest’
option group ‘0’
option forcelink ‘1’
option ipaddr ‘192.168.9.1’
config switch
option name ‘switch0’
option reset ‘1’
option enable_vlan ‘1’
config switch_vlan
option device ‘switch0’
option vlan ‘1’
option ports ‘1 2 3 5t’
config switch_vlan
option vlan ‘2’
option ports ‘0 5t’
config switch_port
option port ‘5’
option pvid ‘2’
r
