I’ve just received a brand new GL-SF2100 and I can’t access the web interface at all on 192.168.8.1.
If I’m connected to it via Ethernet directly or on it’s SSID, my IP address appears as belonging to my ISP’s router subnetwork (192.168.0.xx), so it looks like the SF1200 is working like a bridge but I’m can’t access its management page as I’m not on its own subnetwork. I can access the web with it (I’m actually typing this while on ethernet only on the GL, deactivated WiFi on the PC).
I’ve done a 3s reset and a 10s reset already, it doesn’t change a thing.
The GL-SF2100 is plugged into a Gigabit Linksys switch linked directly to my ISP’s router. Everything seems to go through it as if it where a dumb switch.
Any idea of what I could do to be able to manage the thing ? Thank in advance for your help.
You should be able to default the config on it by:
LEt it boot normally. once settled
Hold the button on the right down for 10 seconds (untill the LEDS flash at you).
This should delete any config and it wil behave as expected.
If its using the pseudo bridging feature in openwrt (relayd0, try giving yourself a static in 192.168.8.1/24 and seeing if you can then reach 192.168.8.1
There is the nuclear option.
Do the same button pressing when powering up and reload the firmware.
Instructions at Debrick via Uboot - GL.iNet Docs
Given neither you and I quite know how its configured. You might be better with the latter anyway!
Ok I 've just done that, the router didn’t do the 3 or 5 times blinking but seemed to boot normally (and yes I was pressing firmly on the rest button). But now the I can’t establish an Ethernet connection with it and its SSID doesn’t appear anymore.
As I’ve no access to the LAN I can’t change my IP to 192.168.1.2
I think this model is defective, I’ve just received it from Amazon, still sealed and didn’t have the chance to mess with its configuration.
