I bought a GL-SF1200 and it has problems trying to capture a 5GHz SSID manually using the Other… option (after scanning). The problem is that the web interface shows the option for network type disabled ( 2.4GHz in gray color) and therefore I cannot select the 5GHz option.
Thank you for your feedback.
We have fixed this issue in version 3.206 and updated the snapshot image of 3.206. You can update the image and test it again.
openwrt-sf1200-3.206-1109.bin
I really appreciate the help to fix the reported issue, it really was a quick response. I have loaded the new image and everything works OK.
Best regards
