Remote Access Bug
Enabling GoodCloud gives the following error & the device does not connect to GoodCloud.
url = https://gslb-jp.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx×tamp=1628338464&sign=74d933c98820f76baf800bbbb5e6bdd4
utils_NLB failed!
Tried both testing and current release firmware but no luck!
3.204 (Testing)
3.203 (Release)
PS: Device is configured in Access Point Mode (Network Mode)
Please guide
Thank you
Thanks for feedback, our server have been upgraded recently and we need to check log of server if have any problem.
I received a device online notification email however on the goodcloud website it shows deactivated. Is it because of the testing firmware?
alzhao
4
Can you make sure the region setting on the device is the same as you are accessing on the cloud?
Yes, it matches
Asia / Pacific
Logs
mqtt init success!
Subscribe succeeded
But on the glinet app I get an error “device is not activated”
However the device status is online
But I’m not able to access any settings
Is everything fine with release firmware now?
can you please the link to the latest release firmware. Im not able to find it on gl-inet website.
I shall re flash and update
thank you
la3y
8
sorry,
my bad … I just checked the last 3 digits of the release
flashing it now!
it also shows warning of firmware being older than the one installed … I think it is due the testing version no which is 204
FIXED!
thank you all for the support
