I just bought a GL-SF1200 and I’m using it as a repeater, the problem is that the SSID disappear when I’m watching any streaming service, the only way to restore it back is connecting to the router on the 5Ghz SSID and then disabling and re-enabling the 2.4 Ghz SSID , it’s already running 3.212 firmware, it only fails during streamings.
any idea on how to solve this?
Many thanks!
alzhao
June 28, 2022, 10:07am
2
So the router use 2.4G to repeat and use 5G to broadcast? Can you specify?
it’s broadcasting on both and using 2.4G to repeat, please find attached the “Wireless overview”
Many thanks!
alzhao
July 4, 2022, 10:01am
4
I see. Seems you use 2.4G to repeater and broadcast on both 2.4G and 5G.
When this happens, can you get the log? You can get the log from Luci.
This is the log minutes before/after the drop:
Mon Jul 4 21:30:04 2022 kern.warn kernel: [ 1214.229084] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[0 247 0 0] rx 176
Mon Jul 4 21:30:48 2022 kern.warn kernel: [ 1257.738566] vif 1 tye 3 change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[0 835 0 0] rx 309
Mon Jul 4 21:30:50 2022 kern.warn kernel: [ 1260.129007] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[0 237 0 0] rx 168
Mon Jul 4 21:30:56 2022 kern.warn kernel: [ 1266.138549] vif 1 tye 3 change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[0 1094 0 0] rx 427
Mon Jul 4 21:30:58 2022 kern.warn kernel: [ 1267.698969] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[2 422 0 0] rx 126
Mon Jul 4 21:31:03 2022 kern.warn kernel: [ 1273.438915] change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[0 867 0 0] rx 415
Mon Jul 4 21:31:05 2022 kern.warn kernel: [ 1275.093106] change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[2 271 0 0] rx 252
Mon Jul 4 21:31:10 2022 kern.warn kernel: [ 1279.848817] vif 1 tye 3 change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[1 906 0 0] rx 389
Mon Jul 4 21:31:12 2022 kern.warn kernel: [ 1281.968721] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[1 272 0 0] rx 137
Mon Jul 4 21:31:15 2022 kern.warn kernel: [ 1285.145311] change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[0 922 0 0] rx 385
Mon Jul 4 21:31:16 2022 kern.warn kernel: [ 1286.469212] change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[0 582 0 0] rx 512
Mon Jul 4 21:31:30 2022 kern.warn kernel: [ 1299.689484] vif 1 tye 3 change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[2 1073 0 0] rx 473
Mon Jul 4 21:31:31 2022 kern.warn kernel: [ 1301.596332] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[1 251 0 0] rx 76
Mon Jul 4 21:31:42 2022 kern.warn kernel: [ 1311.632975] vif 1 tye 3 change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[0 865 0 0] rx 395
Mon Jul 4 21:31:43 2022 kern.warn kernel: [ 1312.929154] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[0 171 0 0] rx 70
Mon Jul 4 21:31:43 2022 kern.warn kernel: [ 1313.451717] vif 1 tye 3 change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[0 809 0 0] rx 174
Mon Jul 4 21:31:46 2022 kern.warn kernel: [ 1316.039268] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[0 593 0 0] rx 162
Mon Jul 4 21:31:49 2022 kern.warn kernel: [ 1318.939540] vif 1 tye 3 change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[0 1144 0 0] rx 454
Mon Jul 4 21:31:50 2022 kern.warn kernel: [ 1320.572050] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[0 462 0 0] rx 161
Mon Jul 4 21:31:51 2022 kern.warn kernel: [ 1321.093213] vif 1 tye 3 change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[0 924 0 0] rx 171
Mon Jul 4 21:32:01 2022 kern.warn kernel: [ 1331.517152] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[1 357 0 0] rx 86
Mon Jul 4 21:32:04 2022 kern.warn kernel: [ 1334.390140] vif 1 tye 3 change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[0 926 0 0] rx 236
Mon Jul 4 21:32:08 2022 kern.warn kernel: [ 1337.800446] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[0 427 0 0] rx 131
Mon Jul 4 21:32:14 2022 kern.warn kernel: [ 1344.253440] vif 1 tye 3 change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[1 1031 0 0] rx 358
Mon Jul 4 21:32:21 2022 kern.warn kernel: [ 1351.192419] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[0 369 0 0] rx 112
Mon Jul 4 21:32:22 2022 kern.warn kernel: [ 1352.229679] vif 1 tye 3 change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[1 860 0 0] rx 199
Mon Jul 4 21:32:23 2022 kern.warn kernel: [ 1353.530059] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[2 272 0 1] rx 74
Mon Jul 4 21:32:30 2022 kern.warn kernel: [ 1360.169933] vif 1 tye 3 change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[2 1610 0 0] rx 415
Mon Jul 4 21:32:33 2022 kern.warn kernel: [ 1363.131111] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[0 732 0 0] rx 516
Mon Jul 4 21:32:41 2022 kern.warn kernel: [ 1371.196699] vif 1 tye 3 change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[0 949 0 0] rx 231
Mon Jul 4 21:32:43 2022 kern.warn kernel: [ 1373.548414] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[1 173 0 0] rx 70
Mon Jul 4 21:32:52 2022 kern.warn kernel: [ 1382.055628] vif 1 tye 3 change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[0 1047 0 0] rx 281
Mon Jul 4 21:32:54 2022 kern.warn kernel: [ 1384.210144] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[0 332 0 0] rx 115
Mon Jul 4 21:32:56 2022 kern.warn kernel: [ 1385.740303] vif 1 tye 3 change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[0 890 0 0] rx 190
Mon Jul 4 21:32:58 2022 kern.warn kernel: [ 1387.860254] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[0 240 0 0] rx 88
Mon Jul 4 21:32:59 2022 kern.warn kernel: [ 1389.440660] vif 1 tye 3 change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[2 839 0 0] rx 282
Mon Jul 4 21:33:02 2022 kern.warn kernel: [ 1391.843845] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[0 529 0 0] rx 75
Mon Jul 4 21:33:04 2022 kern.warn kernel: [ 1393.792378] lmac[0] {CTXT-0} unlink from {VIF-0}: status=4 nb_vif=2
Mon Jul 4 21:33:04 2022 kern.warn kernel: [ 1393.792421] lmac[0] {CTXT-1} Create channel context: freq=2417MHz bw=20MHz pwr=30dBm
Mon Jul 4 21:33:16 2022 daemon.info hostapd: wlan0: STA 1e:6f:c2:a0:42:a3 IEEE 802.11: authenticated
Mon Jul 4 21:33:16 2022 kern.warn kernel: [ 1393.806456] lmac[0] {CTXT-1} link to {VIF-0}: status=0 nb_vif=0
Mon Jul 4 21:33:16 2022 kern.warn kernel: [ 1406.021130] lmac[1] rc_init: station_id=2 format_mod=4 pre_type=0 short_gi=1 max_bw=2
Mon Jul 4 21:33:16 2022 kern.warn kernel: [ 1406.035072] lmac[1] rc_init: nss_max=1 mcs_max=9 r_idx_min=12 r_idx_max=12 no_samples=10
Mon Jul 4 21:33:16 2022 kern.warn kernel: [ 1406.043408] add sta(1e:6f:c2:a0:42:a3) to hash table 160!
Mon Jul 4 21:33:16 2022 kern.info kernel: [ 1406.048889] hb-fmac 17800000.wifi-hb wlan0: Add sta 2 (1e:6f:c2:a0:42:a3) flags=[WME][AUTHENTICATED][ASSOCIATED]
Mon Jul 4 21:33:16 2022 daemon.info hostapd: wlan0: STA 1e:6f:c2:a0:42:a3 IEEE 802.11: associated (aid 2)
Mon Jul 4 21:33:16 2022 kern.info kernel: [ 1406.061628] hb-fmac 17800000.wifi-hb wlan0: Del key for sta 2 (1e:6f:c2:a0:42:a3)
Mon Jul 4 21:33:16 2022 kern.info kernel: [ 1406.070277] hb-fmac 17800000.wifi-hb wlan0: Del key for sta 2 (1e:6f:c2:a0:42:a3)
Mon Jul 4 21:33:16 2022 kern.info kernel: [ 1406.078369] hb-fmac 17800000.wifi-hb wlan0: Del key for sta 2 (1e:6f:c2:a0:42:a3)
Mon Jul 4 21:33:16 2022 daemon.notice hostapd: wlan0: AP-STA-CONNECTED 1e:6f:c2:a0:42:a3
Mon Jul 4 21:33:16 2022 daemon.info hostapd: wlan0: STA 1e:6f:c2:a0:42:a3 RADIUS: starting accounting session 68EAA0B90ACC58F4
Mon Jul 4 21:33:16 2022 daemon.info hostapd: wlan0: STA 1e:6f:c2:a0:42:a3 WPA: pairwise key handshake completed (RSN)
Mon Jul 4 21:33:16 2022 kern.info kernel: [ 1406.094582] hb-fmac 17800000.wifi-hb wlan0: Add key for sta 2 (1e:6f:c2:a0:42:a3)
Mon Jul 4 21:33:16 2022 daemon.info dnsmasq-dhcp[2143]: DHCPDISCOVER(br-lan) 1e:6f:c2:a0:42:a3
Mon Jul 4 21:33:16 2022 daemon.info dnsmasq-dhcp[2143]: DHCPOFFER(br-lan) 192.168.8.130 1e:6f:c2:a0:42:a3
Mon Jul 4 21:33:17 2022 daemon.info dnsmasq-dhcp[2143]: DHCPREQUEST(br-lan) 192.168.8.130 1e:6f:c2:a0:42:a3
Mon Jul 4 21:33:17 2022 daemon.info dnsmasq-dhcp[2143]: DHCPACK(br-lan) 192.168.8.130 1e:6f:c2:a0:42:a3
Mon Jul 4 21:33:35 2022 kern.warn kernel: [ 1425.472152] [0]Total force ps drop len : 14
This is another one:
Mon Jul 4 22:01:09 2022 daemon.info dnsmasq[2114]: using local addresses only for domain local
Mon Jul 4 22:01:09 2022 daemon.info dnsmasq[2114]: using local addresses only for domain invalid
Mon Jul 4 22:01:09 2022 daemon.info dnsmasq[2114]: using local addresses only for domain bind
Mon Jul 4 22:01:09 2022 daemon.info dnsmasq[2114]: using local addresses only for domain lan
Mon Jul 4 22:01:09 2022 daemon.info dnsmasq[2114]: using nameserver 192.168.1.1#53
Mon Jul 4 22:26:01 2022 user.info mwan3rtmon[2042]: Detect rtchange event.
Mon Jul 4 22:26:02 2022 daemon.info hostapd: wlan1: STA aa:52:0e:32:8f:35 IEEE 802.11: authenticated
Mon Jul 4 22:26:02 2022 kern.warn kernel: [ 98.781196] lmac[0] rc_init: station_id=1 format_mod=2 pre_type=0 short_gi=1 max_bw=0
Mon Jul 4 22:26:02 2022 kern.warn kernel: [ 98.789285] lmac[0] rc_init: nss_max=1 mcs_max=7 r_idx_min=0 r_idx_max=3 no_samples=10
Mon Jul 4 22:26:02 2022 kern.warn kernel: [ 98.799499] add sta(aa:52:0e:32:8f:35) to hash table 50!
Mon Jul 4 22:26:02 2022 kern.info kernel: [ 98.805232] lb-fmac 11000000.wifi-lb wlan1: Add sta 1 (aa:52:0e:32:8f:35) flags=[SHORT_PREAMBLE][WME][AUTHENTICATED][ASSOCIATED]
Mon Jul 4 22:26:02 2022 daemon.info hostapd: wlan1: STA aa:52:0e:32:8f:35 IEEE 802.11: associated (aid 1)
Mon Jul 4 22:26:02 2022 kern.info kernel: [ 98.827639] lb-fmac 11000000.wifi-lb wlan1: Del key for sta 1 (aa:52:0e:32:8f:35)
Mon Jul 4 22:26:02 2022 kern.info kernel: [ 98.856074] lb-fmac 11000000.wifi-lb wlan1: Del key for sta 1 (aa:52:0e:32:8f:35)
Mon Jul 4 22:26:02 2022 kern.info kernel: [ 98.877234] lb-fmac 11000000.wifi-lb wlan1: Del key for sta 1 (aa:52:0e:32:8f:35)
Mon Jul 4 22:26:02 2022 kern.info kernel: [ 98.897544] lb-fmac 11000000.wifi-lb wlan1: Add key for vif(1), key index : 1
Mon Jul 4 22:26:02 2022 kern.info kernel: [ 98.930446] lb-fmac 11000000.wifi-lb wlan1: Add key for sta 1 (aa:52:0e:32:8f:35)
Mon Jul 4 22:26:02 2022 daemon.notice hostapd: wlan1: AP-STA-CONNECTED aa:52:0e:32:8f:35
Mon Jul 4 22:26:02 2022 daemon.info hostapd: wlan1: STA aa:52:0e:32:8f:35 RADIUS: starting accounting session D72553B091324299
Mon Jul 4 22:26:02 2022 daemon.info hostapd: wlan1: STA aa:52:0e:32:8f:35 WPA: pairwise key handshake completed (RSN)
Mon Jul 4 22:26:02 2022 user.notice relay: Reloading relay due to connected of wwan (wlan-sta)
Mon Jul 4 22:26:02 2022 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Mon Jul 4 22:26:04 2022 daemon.info dnsmasq-dhcp[2114]: DHCPREQUEST(br-lan) 192.168.8.220 aa:52:0e:32:8f:35
Mon Jul 4 22:26:04 2022 daemon.info dnsmasq-dhcp[2114]: DHCPACK(br-lan) 192.168.8.220 aa:52:0e:32:8f:35
Mon Jul 4 22:26:06 2022 user.notice relay: Reloading relay due to ifup of wwan (wlan-sta)
Mon Jul 4 22:26:54 2022 daemon.info hostapd: wlan1: STA 9c:8c:6e:d8:44:bf IEEE 802.11: authenticated
Mon Jul 4 22:26:54 2022 kern.warn kernel: [ 151.512711] lmac[0] rc_init: station_id=2 format_mod=2 pre_type=0 short_gi=1 max_bw=0
Mon Jul 4 22:26:54 2022 kern.warn kernel: [ 151.520663] lmac[0] rc_init: nss_max=1 mcs_max=7 r_idx_min=0 r_idx_max=3 no_samples=10
Mon Jul 4 22:26:54 2022 kern.warn kernel: [ 151.528887] add sta(9c:8c:6e:d8:44:bf) to hash table 216!
Mon Jul 4 22:26:54 2022 kern.info kernel: [ 151.534458] lb-fmac 11000000.wifi-lb wlan1: Add sta 2 (9c:8c:6e:d8:44:bf) flags=[SHORT_PREAMBLE][WME][AUTHENTICATED][ASSOCIATED]
Mon Jul 4 22:26:54 2022 daemon.info hostapd: wlan1: STA 9c:8c:6e:d8:44:bf IEEE 802.11: associated (aid 2)
Mon Jul 4 22:26:54 2022 kern.info kernel: [ 151.549705] lb-fmac 11000000.wifi-lb wlan1: Del key for sta 2 (9c:8c:6e:d8:44:bf)
Mon Jul 4 22:26:54 2022 kern.info kernel: [ 151.558484] lb-fmac 11000000.wifi-lb wlan1: Del key for sta 2 (9c:8c:6e:d8:44:bf)
Mon Jul 4 22:26:54 2022 kern.info kernel: [ 151.566741] lb-fmac 11000000.wifi-lb wlan1: Del key for sta 2 (9c:8c:6e:d8:44:bf)
Mon Jul 4 22:26:54 2022 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 9c:8c:6e:d8:44:bf
Mon Jul 4 22:26:54 2022 daemon.info hostapd: wlan1: STA 9c:8c:6e:d8:44:bf RADIUS: starting accounting session E9DDFC785447BDAA
Mon Jul 4 22:26:54 2022 daemon.info hostapd: wlan1: STA 9c:8c:6e:d8:44:bf WPA: pairwise key handshake completed (RSN)
Mon Jul 4 22:26:54 2022 kern.info kernel: [ 151.590856] lb-fmac 11000000.wifi-lb wlan1: Add key for sta 2 (9c:8c:6e:d8:44:bf)
Mon Jul 4 22:26:55 2022 daemon.info dnsmasq-dhcp[2114]: DHCPDISCOVER(br-lan) 9c:8c:6e:d8:44:bf
Mon Jul 4 22:26:55 2022 daemon.info dnsmasq-dhcp[2114]: DHCPOFFER(br-lan) 192.168.8.123 9c:8c:6e:d8:44:bf
Mon Jul 4 22:26:55 2022 daemon.info dnsmasq-dhcp[2114]: DHCPREQUEST(br-lan) 192.168.8.123 9c:8c:6e:d8:44:bf
Mon Jul 4 22:26:55 2022 daemon.info dnsmasq-dhcp[2114]: DHCPACK(br-lan) 192.168.8.123 9c:8c:6e:d8:44:bf Samsung
Mon Jul 4 22:26:57 2022 kern.warn kernel: [ 153.946737] change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[0 861 0 0] rx 249
Mon Jul 4 22:26:57 2022 kern.warn kernel: [ 153.954958] vif 1 tye 3 change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[0 820 0 0] rx 41
Mon Jul 4 22:26:58 2022 kern.warn kernel: [ 155.254934] change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[0 434 0 0] rx 377
Mon Jul 4 22:26:59 2022 kern.warn kernel: [ 156.520895] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[4 10 0 0] rx 19
Mon Jul 4 22:27:11 2022 kern.warn kernel: [ 168.374313] change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[1 1060 0 0] rx 512
Mon Jul 4 22:27:13 2022 kern.warn kernel: [ 169.762234] change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[1 468 0 0] rx 408
Mon Jul 4 22:27:13 2022 kern.warn kernel: [ 170.036695] vif 1 tye 3 change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[2 1134 0 1] rx 429
Mon Jul 4 22:27:16 2022 kern.warn kernel: [ 173.443970] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[0 199 0 0] rx 196
Mon Jul 4 22:27:24 2022 kern.warn kernel: [ 181.431903] vif 1 tye 3 change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[0 1980 0 0] rx 772
Mon Jul 4 22:27:27 2022 kern.warn kernel: [ 184.006340] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[0 105 0 0] rx 84
Mon Jul 4 22:27:29 2022 kern.warn kernel: [ 186.376809] vif 1 tye 3 change from step 3 to 1 (1 for tx 3 for rx) other-be-vi-vo=[0 1273 0 0] rx 479
Mon Jul 4 22:27:31 2022 kern.warn kernel: [ 187.935709] vif 1 tye 3 change from step 1 to 3 (1 for tx 3 for rx) other-be-vi-vo=[0 317 0 0] rx 42
dxf
July 5, 2022, 10:31am
7
trava85:
streamings
What type of streaming service is used? Can you elaborate?
When using a streaming service, how long does it take to have problems? Is it inevitable?
I used SF1200 as a repeater according to your way, connected to 2.4g wifi, and used mobile phones to play videos. I did not repeat the problem.
Mostly with Netflix or Prime, but to be honest also happens sometimes without streaming, doing normal browsing but is not that common, the SSID disappear and is not visible anymore from any of my devices, and this is the second router that I try, I don’t know if is some kind of problem with the main signal, but regardless with the original signal the SSID should not disappear.
dxf
July 6, 2022, 2:34am
9
What device do you use to watch the video? Internet TV, mobile phone or PC?
Can you not modify the WiFi and change the TX power? Just because its on max doesn’t mean it will work better.
My Slate used to have intermittent ssid dropout but when connected it was fine, just had issues finding it to begin with. I’ve just got my beryl and although my many other devices can see the WiFi perfectly fine my Xbox Series X can’t see the beryl AT ALL and needs to be wired via ethernet.
The problem could be the router but it could equally be not the router. You need to find out if there is only one device dropping off or if ALL devices are dropped.
Also, check DHCP lease times and set it to 12 or 24 hours.
I just changed the power to “High” to see how it behaves, when the SSID drops is not visible on any device.
Smart TV but also happens any time while I’m just browsing or working. the weird thing is that is the second router (same model) that I try and the situation is the same.
But looks like the problem occurs when the Wifi activity or the bandwidth usage is high
dxf
July 7, 2022, 2:02am
15
Ok, I will follow up this issue and inform you if it is fixed
dxf
July 15, 2022, 7:53am
16
Hi tarva85:
Can you provide the /etc/config/wireless file in the router?
I tested it for a week but no ssid disappeared.
Hi dengxinfa,
yep, this is the wireless data:
config wifi-device ‘radio0’
option type ‘mac80211’
option txpower ‘25’
option txpower_max ‘25’
option band ‘5G’
option hwmode ‘11a’
option noscan ‘0’
option netisolate ‘0’
option max_all_num_sta ‘64’
option path ‘platform/17800000.wifi-hb’
option htmode ‘VHT80’
option disabled ‘0’
option country ‘CN’
option acs_noradar ‘1’
option org_htmode ‘VHT80’
option channel ‘56’
config wifi-iface ‘default_radio0’
option device ‘radio0’
option network ‘lan’
option mode ‘ap’
option hidden ‘0’
option ifname ‘wlan0’
option wpa_group_rekey ‘36000’
option isolate ‘0’
option group ‘1’
option disable_input ‘0’
option wps_pushbutton ‘1’
option wps_label ‘0’
option ssid ‘GL-SF1200-205-5G’
option encryption ‘psk2’
option key ‘goodlife’
option disassoc_low_ack ‘0’
option wds ‘1’
config wifi-device ‘radio1’
option txpower_max ‘20’
option band ‘2G’
option hwmode ‘11g’
option noscan ‘0’
option path ‘platform/11000000.wifi-lb’
option htmode ‘HT40’
option country ‘CN’
option txpower ‘23’
option channel ‘1’
config wifi-iface ‘default_radio1’
option device ‘radio1’
option mode ‘ap’
option hidden ‘0’
option ifname ‘wlan1’
option isolate ‘0’
option group ‘1’
option ssid ‘GL-SF1200-205’
option wds ‘1’
option disabled ‘0’
option encryption ‘psk-mixed’
config wifi-iface ‘guest5g’
option network ‘guest’
option mode ‘ap’
option wds ‘1’
option ssid ‘GL-SF1200-205-Guest-5G’
option ifname ‘wlan2’
option disabled ‘1’
option guest ‘1’
config wifi-iface ‘guest2g’
option mode ‘ap’
option wds ‘1’
option ssid ‘GL-SF1200-205-Guest’
option ifname ‘wlan3’
option disabled ‘1’
option guest ‘1’
config wifi-iface ‘sta’
option network ‘wwan’
option mode ‘sta’
option ifname ‘wlan-sta’
option ssid ‘Vodafone-38307506’
option bssid ‘E4:8F:34:3B:D6:0C’
option channel ‘1’
option key ‘llvwuy54wzhae8z’
