GL-SFT1200 and WPS printer
how can I connect a printer allowing only WPS to my GL-SFT 1200?
Thank you all for your help.
Unfortunately, the SFT1200 do not support the WPS feature.
You may want to contact the printer’s vendor to see if there is a way to manually enter the SSID and password.
Hi will.qiu,
Thank you for the fast reply.
I had this suspect and I’ll check the printer’s web pages. So all I need to do is enter SSID and password on printer side. Any configuration to be entered on router side?
Yes, typically you just need to select or enter the SSID and password on the printer’s configuration page.
By default, the Wi-Fi on the SFT1200 is already enabled, allowing other devices to connect.
