It keeps error out for comp_zlib: symbol not found when trying to execute stunnel. Tried the beta version as well bu same error. Can some I ne help?
Have you installed any additional software? Maybe you didn’t select a dependent compilation option at compile time.
Can you share your complete steps?
All i did is in the plugin, just chose “stunnel” to install. That is all.
I also got gl-ar750 model and i did the same plugin installation.
pls try this ipk
stunnel.zip (73.5 KB)
