GL-SFT1200 DNS for a LAN
Hello, I am trying to set up a LAN using cat5e and two laptops using my GL-SFT1200. I'm running XMPP Openfire on one laptop and need to have an internal DNS in order to utilize Google Chrome's Pade for video/tele conferencing. Does my router have a simple DNS capability for a small network operations?
Thank you!
Yes, it does. You can create simple records using luci, see [OpenWrt Wiki] DHCP and DNS examples
Thank you so much for the reply! I'm new to all of this....how would I install LuCl and the GL version of OpenWrt onto my router? You rock.
I think I figured it out, just getting an internal error 500 now.
