GL-SFT1200 fails to connect mobile hotspot on Windows 10
It's a strange problem. I enabled mobile hotspot on Windows 10, then tried to connect to it on my GL-SFT1200, but never been able to connect, neither 5G or 2.4Ghz. I also tried changing its network mode to Extender, didn't work out.
My GL-AR750S and GL-MT300N both connected without any problem.
Now I have to chain them together, gl-ar750s to windows 10 first, then connect gl-sft1200 to gl-ar750s.
Does anyone know what the problem is? any suggestions?
Please share the syslog of the SFT1200 when it (try) connects to the Windows10.
Please let me know the Windows10 Wireless adapter chip model.
Wifi is Intel Wi-Fi 6 AX201 160MHz. I don't see syslog on left side Admin Panel. where is it when I ssh to it?
Wifi is Intel Wi-Fi 6 AX201 160MHz. I don't see syslog on left side Admin Panel. where is it when I ssh to it? I don't see it under /var/log.
System > Log
or via SSH you can use logread
There is no System. There is no Log. They are not in ADMIN PANEL.
Here's log output, I have to discard some beginning lines due to word count limit:
Fri Oct 25 03:30:46 2024 kern.info kernel: [10704.420119] br-lan: port 2(wlan0) entered forwarding state
Fri Oct 25 03:30:46 2024 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Fri Oct 25 03:30:46 2024 daemon.notice hostapd: wlan0: interface state COUNTRY_UPDATE->HT_SCAN
Fri Oct 25 03:30:46 2024 kern.warn kernel: [10704.457755] lmac[0] vif_mgmt_register, vif_type : 2 status=0 index=1, req_idx=0
Fri Oct 25 03:30:46 2024 kern.warn kernel: [10704.465274] lmac[0] use low txpower table
Fri Oct 25 03:30:46 2024 kern.info kernel: [10704.490495] br-lan: port 3(wlan1) entered blocking state
Fri Oct 25 03:30:46 2024 kern.info kernel: [10704.496132] br-lan: port 3(wlan1) entered disabled state
Fri Oct 25 03:30:46 2024 kern.info kernel: [10704.504992] device wlan1 entered promiscuous mode
Fri Oct 25 03:30:46 2024 kern.info kernel: [10704.512007] br-lan: port 3(wlan1) entered blocking state
Fri Oct 25 03:30:46 2024 kern.info kernel: [10704.517567] br-lan: port 3(wlan1) entered forwarding state
Fri Oct 25 03:30:46 2024 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
Fri Oct 25 03:30:46 2024 daemon.notice hostapd: wlan1: interface state COUNTRY_UPDATE->HT_SCAN
Fri Oct 25 03:30:46 2024 daemon.notice hostapd: Switch own primary and secondary channel to get secondary channel with no Beacons from other BSSes
Fri Oct 25 03:30:46 2024 daemon.warn hostapd: wlan0: Could not connect to kernel driver
Fri Oct 25 03:30:46 2024 kern.info kernel: [10704.677221] hb-fmac 17800000.wifi-hb wlan0: Del key for vif(0), key index : 0
Fri Oct 25 03:30:46 2024 kern.info kernel: [10704.685168] hb-fmac 17800000.wifi-hb wlan0: Del key for vif(0), key index : 1
Fri Oct 25 03:30:46 2024 kern.info kernel: [10704.693055] hb-fmac 17800000.wifi-hb wlan0: Del key for vif(0), key index : 2
Fri Oct 25 03:30:46 2024 daemon.notice wpa_supplicant[6499]: wlan-sta: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Fri Oct 25 03:30:46 2024 daemon.err hostapd: Using interface wlan0 with hwaddr 94:83:c4:3e:f9:ee and ssid "GL-SFT1200-9eb-5G"
Fri Oct 25 03:30:46 2024 kern.info kernel: [10704.702134] hb-fmac 17800000.wifi-hb wlan0: Del key for vif(0), key index : 3
Fri Oct 25 03:30:46 2024 user.notice relay: Reloading relay due to ifup-failed of wwan ()
Fri Oct 25 03:30:46 2024 daemon.notice hostapd: WPS: Converting push_button to virtual_push_button for WPS 2.0 compliance
Fri Oct 25 03:30:46 2024 daemon.notice netifd: Interface 'wwan' is enabled
Fri Oct 25 03:30:46 2024 kern.warn kernel: [10704.906109] lmac[1] {CTXT-0} Create channel context: freq=5200MHz bw=80MHz pwr=23dBm
Fri Oct 25 03:30:46 2024 kern.warn kernel: [10704.914075] lmac[1] {CTXT-0} link to {VIF-0}: status=0 nb_vif=0
Fri Oct 25 03:30:46 2024 kern.info kernel: [10704.916893] hb-fmac 17800000.wifi-hb wlan0: AP started: ch=0, bcmc_idx=64
Fri Oct 25 03:30:46 2024 kern.info kernel: [10704.934539] hb-fmac 17800000.wifi-hb wlan0: Add key for vif(0), key index : 1
Fri Oct 25 03:30:46 2024 daemon.notice hostapd: wlan0: interface state HT_SCAN->ENABLED
Fri Oct 25 03:30:46 2024 daemon.notice hostapd: wlan0: AP-ENABLED
Fri Oct 25 03:30:47 2024 daemon.notice netifd: Network device 'wlan0' link is up
Fri Oct 25 03:30:47 2024 kern.info kernel: [10705.257039] br-lan: port 3(wlan1) entered disabled state
Fri Oct 25 03:30:47 2024 daemon.notice wpa_supplicant[6499]: wlan-sta: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Fri Oct 25 03:30:47 2024 daemon.notice hostapd: 20/40 MHz operation not permitted on channel pri=1 sec=5 based on overlapping BSSes
Fri Oct 25 03:30:47 2024 daemon.warn hostapd: wlan1: Could not connect to kernel driver
Fri Oct 25 03:30:47 2024 kern.info kernel: [10705.757337] lb-fmac 11000000.wifi-lb wlan1: Del key for vif(1), key index : 0
Fri Oct 25 03:30:47 2024 kern.info kernel: [10705.765200] lb-fmac 11000000.wifi-lb wlan1: Del key for vif(1), key index : 1
Fri Oct 25 03:30:47 2024 kern.info kernel: [10705.773059] lb-fmac 11000000.wifi-lb wlan1: Del key for vif(1), key index : 2
Fri Oct 25 03:30:47 2024 kern.info kernel: [10705.780990] lb-fmac 11000000.wifi-lb wlan1: Del key for vif(1), key index : 3
Fri Oct 25 03:30:47 2024 daemon.err hostapd: Using interface wlan1 with hwaddr 94:83:c4:3e:f9:ed and ssid "GL-SFT1200-9eb"
Fri Oct 25 03:30:47 2024 daemon.notice hostapd: WPS: Converting push_button to virtual_push_button for WPS 2.0 compliance
Fri Oct 25 03:30:47 2024 kern.warn kernel: [10705.955515] lmac[0] {CTXT-0} Create channel context: freq=2412MHz bw=20MHz pwr=30dBm
Fri Oct 25 03:30:47 2024 kern.warn kernel: [10705.963354] lmac[0] {CTXT-0} link to {VIF-1}: status=0 nb_vif=0
Fri Oct 25 03:30:47 2024 kern.info kernel: [10705.963733] lb-fmac 11000000.wifi-lb wlan1: AP started: ch=0, bcmc_idx=65
Fri Oct 25 03:30:47 2024 kern.info kernel: [10705.976811] br-lan: port 3(wlan1) entered blocking state
Fri Oct 25 03:30:47 2024 kern.info kernel: [10705.982259] br-lan: port 3(wlan1) entered forwarding state
Fri Oct 25 03:30:48 2024 daemon.notice hostapd: wlan1: interface state HT_SCAN->ENABLED
Fri Oct 25 03:30:48 2024 kern.info kernel: [10705.990683] lb-fmac 11000000.wifi-lb wlan1: Add key for vif(1), key index : 1
Fri Oct 25 03:30:48 2024 daemon.notice hostapd: wlan1: AP-ENABLED
Fri Oct 25 03:30:48 2024 daemon.notice netifd: Network device 'wlan1' link is up
Fri Oct 25 03:30:49 2024 daemon.notice wpa_supplicant[6499]: wlan-sta: Trying to associate with 4e:03:4f:5b:f3:74 (SSID='LT03338 9732' freq=2412 MHz)
Fri Oct 25 03:30:49 2024 kern.warn kernel: [10707.446481] lmac[0] {CTXT-0} link to {VIF-0}: status=2 nb_vif=1
Fri Oct 25 03:30:49 2024 kern.warn kernel: [10707.446537] lmac[0] rc_init: station_id=0 format_mod=2 pre_type=0 short_gi=1 max_bw=0
Fri Oct 25 03:30:49 2024 kern.warn kernel: [10707.460338] lmac[0] rc_init: nss_max=1 mcs_max=7 r_idx_min=0 r_idx_max=3 no_samples=10
Fri Oct 25 03:30:49 2024 daemon.notice wpa_supplicant[6499]: wlan-sta: CTRL-EVENT-ASSOC-REJECT bssid=00:00:00:00:00:00 status_code=45
Fri Oct 25 03:30:49 2024 daemon.notice netifd: Network device 'wlan-sta' link is up
Fri Oct 25 03:30:49 2024 daemon.notice netifd: Interface 'wwan' has link connectivity
Fri Oct 25 03:30:49 2024 daemon.notice netifd: Interface 'wwan' is setting up now
Fri Oct 25 03:30:49 2024 daemon.notice netifd: wwan (6967): udhcpc: started, v1.29.3
Fri Oct 25 03:30:49 2024 daemon.notice netifd: wwan (6967): udhcpc: sending discover
Fri Oct 25 03:30:50 2024 daemon.notice wpa_supplicant[6499]: wlan-sta: Trying to associate with 4e:03:4f:5b:f3:74 (SSID='LT03338 9732' freq=2412 MHz)
Fri Oct 25 03:30:50 2024 kern.warn kernel: [10707.468374] lmac[0] {CTXT-0} unlink from {VIF-0}: status=4 nb_vif=2
Fri Oct 25 03:30:50 2024 kern.warn kernel: [10708.306839] lmac[0] {CTXT-0} link to {VIF-0}: status=2 nb_vif=1
Fri Oct 25 03:30:50 2024 kern.warn kernel: [10708.313228] lmac[0] rc_init: station_id=1 format_mod=2 pre_type=0 short_gi=1 max_bw=0
Fri Oct 25 03:30:50 2024 kern.warn kernel: [10708.327362] lmac[0] rc_init: nss_max=1 mcs_max=7 r_idx_min=0 r_idx_max=3 no_samples=10
Fri Oct 25 03:30:50 2024 daemon.notice wpa_supplicant[6499]: wlan-sta: CTRL-EVENT-ASSOC-REJECT bssid=00:00:00:00:00:00 status_code=45
Fri Oct 25 03:30:51 2024 daemon.notice wpa_supplicant[6499]: wlan-sta: Trying to associate with 4e:03:4f:5b:f3:74 (SSID='LT03338 9732' freq=2412 MHz)
Fri Oct 25 03:30:51 2024 kern.warn kernel: [10708.335454] lmac[0] {CTXT-0} unlink from {VIF-0}: status=4 nb_vif=2
Fri Oct 25 03:30:51 2024 kern.warn kernel: [10709.574687] lmac[0] {CTXT-0} link to {VIF-0}: status=2 nb_vif=1
Fri Oct 25 03:30:51 2024 kern.warn kernel: [10709.581056] lmac[0] rc_init: station_id=2 format_mod=2 pre_type=0 short_gi=1 max_bw=0
Fri Oct 25 03:30:51 2024 kern.warn kernel: [10709.595134] lmac[0] rc_init: nss_max=1 mcs_max=7 r_idx_min=0 r_idx_max=3 no_samples=10
Fri Oct 25 03:30:51 2024 daemon.notice wpa_supplicant[6499]: wlan-sta: CTRL-EVENT-ASSOC-REJECT bssid=00:00:00:00:00:00 status_code=45
Fri Oct 25 03:30:52 2024 daemon.notice netifd: wwan (6967): udhcpc: sending discover
Fri Oct 25 03:30:53 2024 daemon.notice wpa_supplicant[6499]: wlan-sta: Trying to associate with 4e:03:4f:5b:f3:74 (SSID='LT03338 9732' freq=2412 MHz)
Fri Oct 25 03:30:53 2024 kern.warn kernel: [10709.603198] lmac[0] {CTXT-0} unlink from {VIF-0}: status=4 nb_vif=2
Fri Oct 25 03:30:53 2024 kern.warn kernel: [10711.358070] lmac[0] {CTXT-0} link to {VIF-0}: status=2 nb_vif=1
Fri Oct 25 03:30:53 2024 kern.warn kernel: [10711.364552] lmac[0] rc_init: station_id=3 format_mod=2 pre_type=0 short_gi=1 max_bw=0
Fri Oct 25 03:30:53 2024 kern.warn kernel: [10711.378481] lmac[0] rc_init: nss_max=1 mcs_max=7 r_idx_min=0 r_idx_max=3 no_samples=10
Fri Oct 25 03:30:53 2024 daemon.notice wpa_supplicant[6499]: wlan-sta: CTRL-EVENT-ASSOC-REJECT bssid=00:00:00:00:00:00 status_code=45
Fri Oct 25 03:30:53 2024 daemon.notice wpa_supplicant[6499]: wlan-sta: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="LT03338 9732" auth_failures=1 duration=10 reason=CONN_FAILED
Fri Oct 25 03:30:55 2024 daemon.notice netifd: wwan (6967): udhcpc: sending discover
Fri Oct 25 03:31:03 2024 daemon.notice wpa_supplicant[6499]: wlan-sta: CTRL-EVENT-SSID-REENABLED id=0 ssid="LT03338 9732"
Fri Oct 25 03:31:03 2024 daemon.notice wpa_supplicant[6499]: wlan-sta: Trying to associate with 4e:03:4f:5b:f3:74 (SSID='LT03338 9732' freq=2412 MHz)
Fri Oct 25 03:31:03 2024 kern.warn kernel: [10711.386613] lmac[0] {CTXT-0} unlink from {VIF-0}: status=4 nb_vif=2
Fri Oct 25 03:31:03 2024 kern.warn kernel: [10721.129235] lmac[0] {CTXT-0} link to {VIF-0}: status=2 nb_vif=1
Fri Oct 25 03:31:03 2024 kern.warn kernel: [10721.135582] lmac[0] rc_init: station_id=4 format_mod=2 pre_type=0 short_gi=1 max_bw=0
Fri Oct 25 03:31:03 2024 kern.warn kernel: [10721.149403] lmac[0] rc_init: nss_max=1 mcs_max=7 r_idx_min=0 r_idx_max=3 no_samples=10
Fri Oct 25 03:31:03 2024 daemon.notice wpa_supplicant[6499]: wlan-sta: CTRL-EVENT-ASSOC-REJECT bssid=00:00:00:00:00:00 status_code=45
Fri Oct 25 03:31:03 2024 daemon.notice wpa_supplicant[6499]: wlan-sta: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="LT03338 9732" auth_failures=2 duration=20 reason=CONN_FAILED
Fri Oct 25 03:31:11 2024 daemon.info hostapd: wlan0: STA c8:58:c0:e6:da:e8 IEEE 802.11: authenticated
Fri Oct 25 03:31:11 2024 kern.warn kernel: [10721.157358] lmac[0] {CTXT-0} unlink from {VIF-0}: status=4 nb_vif=2
Fri Oct 25 03:31:11 2024 kern.warn kernel: [10729.000055] lmac[1] rc_init: station_id=0 format_mod=4 pre_type=0 short_gi=1 max_bw=2
Fri Oct 25 03:31:11 2024 kern.warn kernel: [10729.014371] lmac[1] rc_init: nss_max=1 mcs_max=9 r_idx_min=12 r_idx_max=12 no_samples=10
Fri Oct 25 03:31:11 2024 kern.warn kernel: [10729.022847] add sta(c8:58:c0:e6:da:e8) to hash table 230!
Fri Oct 25 03:31:11 2024 kern.info kernel: [10729.028988] hb-fmac 17800000.wifi-hb wlan0: Add sta 0 (c8:58:c0:e6:da:e8) flags=[SHORT_PREAMBLE][WME][AUTHENTICATED][ASSOCIATED]
Fri Oct 25 03:31:11 2024 daemon.info hostapd: wlan0: STA c8:58:c0:e6:da:e8 IEEE 802.11: associated (aid 1)
Fri Oct 25 03:31:11 2024 kern.info kernel: [10729.042807] hb-fmac 17800000.wifi-hb wlan0: Del key for sta 0 (c8:58:c0:e6:da:e8)
Fri Oct 25 03:31:11 2024 kern.info kernel: [10729.052335] hb-fmac 17800000.wifi-hb wlan0: Del key for sta 0 (c8:58:c0:e6:da:e8)
Fri Oct 25 03:31:11 2024 kern.info kernel: [10729.060701] hb-fmac 17800000.wifi-hb wlan0: Del key for sta 0 (c8:58:c0:e6:da:e8)
Fri Oct 25 03:31:11 2024 kern.info kernel: [10729.070801] hb-fmac 17800000.wifi-hb wlan0: Add key for vif(0), key index : 1
Fri Oct 25 03:31:11 2024 daemon.notice hostapd: wlan0: AP-STA-CONNECTED c8:58:c0:e6:da:e8
Fri Oct 25 03:31:11 2024 daemon.info hostapd: wlan0: STA c8:58:c0:e6:da:e8 RADIUS: starting accounting session 1F9CE9584DD2D549
Fri Oct 25 03:31:11 2024 daemon.info hostapd: wlan0: STA c8:58:c0:e6:da:e8 WPA: pairwise key handshake completed (RSN)
Fri Oct 25 03:31:11 2024 kern.info kernel: [10729.088431] hb-fmac 17800000.wifi-hb wlan0: Add key for sta 0 (c8:58:c0:e6:da:e8)
Fri Oct 25 03:31:11 2024 daemon.info dnsmasq-dhcp[2112]: DHCPREQUEST(br-lan) 192.168.2.158 c8:58:c0:e6:da:e8
Fri Oct 25 03:31:11 2024 daemon.info dnsmasq-dhcp[2112]: DHCPACK(br-lan) 192.168.2.158 c8:58:c0:e6:da:e8 DESKTOP-J6PRVGS
Fri Oct 25 03:31:15 2024 user.info : [ 817] gl-sdk>> wifi_join return=-5, channel=-1
Fri Oct 25 03:31:15 2024 user.info : [ 1754] gl-wifi-core>> Restart wifi...
Fri Oct 25 03:31:15 2024 daemon.notice hostapd: wlan1: interface state ENABLED->DISABLED
Fri Oct 25 03:31:15 2024 daemon.notice hostapd: wlan1: AP-DISABLED
Fri Oct 25 03:31:15 2024 daemon.notice hostapd: wlan1: CTRL-EVENT-TERMINATING
Fri Oct 25 03:31:15 2024 kern.warn kernel: [10733.753602] tx pkt(0) deauth to [ff:ff:ff:ff:ff:ff] reasoncode: 3
Fri Oct 25 03:31:15 2024 daemon.notice hostapd: wlan0: interface state ENABLED->DISABLED
Fri Oct 25 03:31:15 2024 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED c8:58:c0:e6:da:e8
Fri Oct 25 03:31:15 2024 daemon.notice hostapd: wlan0: AP-DISABLED
Fri Oct 25 03:31:15 2024 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Fri Oct 25 03:31:15 2024 kern.warn kernel: [10733.818259] tx pkt(1) deauth to [ff:ff:ff:ff:ff:ff] reasoncode: 3
Fri Oct 25 03:31:15 2024 daemon.notice hostapd: nl80211: deinit ifname=wlan1 disabled_11b_rates=0
Fri Oct 25 03:31:15 2024 daemon.notice wpa_supplicant[6499]: nl80211: deinit ifname=wlan-sta disabled_11b_rates=0
Fri Oct 25 03:31:15 2024 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Fri Oct 25 03:31:15 2024 kern.info kernel: [10733.904105] device wlan1 left promiscuous mode
Fri Oct 25 03:31:15 2024 kern.info kernel: [10733.908866] br-lan: port 3(wlan1) entered disabled state
Fri Oct 25 03:31:15 2024 kern.warn kernel: [10733.966586] lmac[0] {CTXT-0} unlink from {VIF-1}: status=4 nb_vif=1
Fri Oct 25 03:31:15 2024 kern.warn kernel: [10733.966626] lmac[0] {CTXT-0} Delete channel context
Fri Oct 25 03:31:15 2024 kern.info kernel: [10733.973174] lb-fmac 11000000.wifi-lb wlan1: AP Stopped
Fri Oct 25 03:31:15 2024 daemon.notice netifd: Network device 'wlan1' link is down
Fri Oct 25 03:31:15 2024 daemon.notice wpa_supplicant[6499]: wlan-sta: CTRL-EVENT-TERMINATING
Fri Oct 25 03:31:16 2024 kern.info kernel: [10733.988754] device wlan0 left promiscuous mode
Fri Oct 25 03:31:16 2024 kern.info kernel: [10733.993569] br-lan: port 2(wlan0) entered disabled state
Fri Oct 25 03:31:16 2024 daemon.notice netifd: radio0 (7688): Command failed: Invalid argument
Fri Oct 25 03:31:16 2024 kern.warn kernel: [10734.066495] lmac[1] {CTXT-0} unlink from {VIF-0}: status=4 nb_vif=1
Fri Oct 25 03:31:16 2024 kern.warn kernel: [10734.066528] lmac[1] {CTXT-0} Delete channel context
Fri Oct 25 03:31:16 2024 kern.info kernel: [10734.072925] hb-fmac 17800000.wifi-hb wlan0: Del sta 0 (c8:58:c0:e6:da:e8)
Fri Oct 25 03:31:16 2024 kern.warn kernel: [10734.085258] remove STA c8:58:c0:e6:da:e8 from hash table success
Fri Oct 25 03:31:16 2024 kern.info kernel: [10734.091407] hb-fmac 17800000.wifi-hb wlan0: AP Stopped
Fri Oct 25 03:31:16 2024 kern.info kernel: [10734.099473] lb-fmac 11000000.wifi-lb wlan1: CLOSE
Fri Oct 25 03:31:16 2024 kern.warn kernel: [10734.104464] lmac[0] vif_mgmt_unregister index=1
Fri Oct 25 03:31:16 2024 kern.info kernel: [10734.159250] hb-fmac 17800000.wifi-hb wlan0: CLOSE
Fri Oct 25 03:31:16 2024 kern.warn kernel: [10734.164339] lmac[1] vif_mgmt_unregister index=0
Fri Oct 25 03:31:16 2024 kern.warn kernel: [10734.171705] rx_bufsz - 2560, rx_pd_offset - 224
Fri Oct 25 03:31:16 2024 daemon.notice netifd: Network device 'wlan0' link is down
Fri Oct 25 03:31:16 2024 kern.info kernel: [10734.206320] lb-fmac 11000000.wifi-lb wlan1: Remove Interface
Fri Oct 25 03:31:16 2024 kern.warn kernel: [10734.212154] found hnat device to del
Fri Oct 25 03:31:16 2024 kern.info kernel: [10734.276898] lb-fmac 11000000.wifi-lb wlan1 (unregistering): Remove Interface Over
Fri Oct 25 03:31:16 2024 kern.info kernel: [10734.335490] hb-fmac 17800000.wifi-hb wlan0: Remove Interface
Fri Oct 25 03:31:16 2024 kern.warn kernel: [10734.341235] found hnat device to del
Fri Oct 25 03:31:16 2024 kern.info kernel: [10734.416445] hb-fmac 17800000.wifi-hb wlan0 (unregistering): Remove Interface Over
Fri Oct 25 03:31:16 2024 daemon.notice netifd: radio1 (7751): Command failed: Invalid argument
Fri Oct 25 03:31:16 2024 daemon.notice netifd: radio0 (7801): Command failed: Invalid argument
Fri Oct 25 03:31:16 2024 kern.info kernel: [10734.820916] lb-fmac 11000000.wifi-lb wlan-sta: CLOSE
Fri Oct 25 03:31:16 2024 kern.warn kernel: [10734.826229] lmac[0] vif_mgmt_unregister index=0
Fri Oct 25 03:31:16 2024 daemon.notice netifd: Network device 'wlan-sta' link is down
Fri Oct 25 03:31:16 2024 daemon.notice netifd: Interface 'wwan' has link connectivity loss
Fri Oct 25 03:31:16 2024 kern.warn kernel: [10734.834013] rx_bufsz - 2560, rx_pd_offset - 224
Fri Oct 25 03:31:16 2024 daemon.notice netifd: wwan (6967): udhcpc: read error: Network is down, reopening socket
Fri Oct 25 03:31:16 2024 kern.info kernel: [10734.845404] lb-fmac 11000000.wifi-lb wlan-sta: Del key for vif(0), key index : 0
Fri Oct 25 03:31:16 2024 kern.info kernel: [10734.852952] lb-fmac 11000000.wifi-lb wlan-sta: Del key for vif(0), key index : 1
Fri Oct 25 03:31:16 2024 kern.info kernel: [10734.860694] lb-fmac 11000000.wifi-lb wlan-sta: Del key for vif(0), key index : 2
Fri Oct 25 03:31:16 2024 kern.info kernel: [10734.868420] lb-fmac 11000000.wifi-lb wlan-sta: Del key for vif(0), key index : 3
Fri Oct 25 03:31:16 2024 kern.info kernel: [10734.876093] lb-fmac 11000000.wifi-lb wlan-sta: Del key for vif(0), key index : 4
Fri Oct 25 03:31:16 2024 kern.info kernel: [10734.883750] lb-fmac 11000000.wifi-lb wlan-sta: Del key for vif(0), key index : 5
Fri Oct 25 03:31:16 2024 kern.info kernel: [10734.903591] lb-fmac 11000000.wifi-lb wlan-sta: Remove Interface
Fri Oct 25 03:31:16 2024 kern.warn kernel: [10734.909801] found hnat device to del
Fri Oct 25 03:31:16 2024 daemon.notice netifd: wwan (6967): udhcpc: bind: No such device
Fri Oct 25 03:31:17 2024 daemon.notice netifd: Interface 'wwan' is disabled
Fri Oct 25 03:31:17 2024 kern.info kernel: [10734.995692] lb-fmac 11000000.wifi-lb wlan-sta (unregistering): Remove Interface Over
Fri Oct 25 03:31:17 2024 user.notice mac80211: Failed command: iw phy phy0 set antenna all all
Fri Oct 25 03:31:17 2024 daemon.notice netifd: radio1 (7751): command failed: Not supported (-122)
Fri Oct 25 03:31:17 2024 user.notice mac80211: Failed command: iw phy phy0 set antenna_gain 0
Fri Oct 25 03:31:17 2024 user.notice mac80211: Failed command: iw phy phy1 set antenna all all
Fri Oct 25 03:31:17 2024 daemon.notice netifd: radio0 (7801): command failed: Not supported (-122)
Fri Oct 25 03:31:17 2024 user.notice mac80211: Failed command: iw phy phy1 set antenna_gain 0
Fri Oct 25 03:31:17 2024 daemon.notice netifd: radio1 (7889): Command failed: Invalid argument
Fri Oct 25 03:31:17 2024 kern.warn kernel: [10735.497856] found hnat device to add
Fri Oct 25 03:31:17 2024 kern.warn kernel: [10735.501564] [hnat notice]add wifi dev index 7 ndev84e4e000
Fri Oct 25 03:31:17 2024 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Fri Oct 25 03:31:17 2024 kern.warn kernel: [10735.572339] lmac[0] vif_mgmt_register, vif_type : 2 status=0 index=0, req_idx=0
Fri Oct 25 03:31:17 2024 kern.warn kernel: [10735.579853] lmac[0] use low txpower table
Fri Oct 25 03:31:17 2024 kern.info kernel: [10735.594965] br-lan: port 2(wlan1) entered blocking state
Fri Oct 25 03:31:17 2024 kern.info kernel: [10735.600395] br-lan: port 2(wlan1) entered disabled state
Fri Oct 25 03:31:17 2024 kern.info kernel: [10735.607161] device wlan1 entered promiscuous mode
Fri Oct 25 03:31:17 2024 kern.info kernel: [10735.614163] br-lan: port 2(wlan1) entered blocking state
Fri Oct 25 03:31:17 2024 kern.info kernel: [10735.619609] br-lan: port 2(wlan1) entered forwarding state
Fri Oct 25 03:31:17 2024 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
Fri Oct 25 03:31:17 2024 daemon.notice hostapd: wlan1: interface state COUNTRY_UPDATE->HT_SCAN
Fri Oct 25 03:31:17 2024 kern.warn kernel: [10735.873375] found hnat device to add
Fri Oct 25 03:31:17 2024 kern.warn kernel: [10735.877185] [hnat notice]add wifi dev index 6 ndev84edf000
Fri Oct 25 03:31:17 2024 daemon.err hostapd: Configuration file: /var/run/hostapd-phy1.conf
Fri Oct 25 03:31:17 2024 kern.warn kernel: [10735.940308] lmac[1] vif_mgmt_register, vif_type : 2 status=0 index=0, req_idx=0
Fri Oct 25 03:31:17 2024 kern.warn kernel: [10735.947844] lmac[1] use low txpower table
Fri Oct 25 03:31:17 2024 kern.info kernel: [10735.963008] br-lan: port 3(wlan0) entered blocking state
Fri Oct 25 03:31:17 2024 kern.info kernel: [10735.968599] br-lan: port 3(wlan0) entered disabled state
Fri Oct 25 03:31:17 2024 kern.info kernel: [10735.977004] device wlan0 entered promiscuous mode
Fri Oct 25 03:31:17 2024 kern.info kernel: [10735.983538] br-lan: port 3(wlan0) entered blocking state
Fri Oct 25 03:31:18 2024 kern.info kernel: [10735.989070] br-lan: port 3(wlan0) entered forwarding state
Fri Oct 25 03:31:18 2024 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Fri Oct 25 03:31:18 2024 daemon.notice hostapd: wlan0: interface state COUNTRY_UPDATE->HT_SCAN
Fri Oct 25 03:31:18 2024 kern.info kernel: [10736.016175] br-lan: port 2(wlan1) entered disabled state
Fri Oct 25 03:31:18 2024 kern.info kernel: [10736.027982] br-lan: port 3(wlan0) entered disabled state
Fri Oct 25 03:31:18 2024 user.notice relay: Reloading relay due to ifup-failed of wwan ()
Fri Oct 25 03:31:18 2024 daemon.notice hostapd: handle_probe_req: send failed
Fri Oct 25 03:31:18 2024 daemon.notice hostapd: Switch own primary and secondary channel to get secondary channel with no Beacons from other BSSes
Fri Oct 25 03:31:18 2024 daemon.warn hostapd: wlan0: Could not connect to kernel driver
Fri Oct 25 03:31:18 2024 kern.info kernel: [10736.228907] hb-fmac 17800000.wifi-hb wlan0: Del key for vif(0), key index : 0
Fri Oct 25 03:31:18 2024 kern.info kernel: [10736.236813] hb-fmac 17800000.wifi-hb wlan0: Del key for vif(0), key index : 1
Fri Oct 25 03:31:18 2024 kern.info kernel: [10736.245446] hb-fmac 17800000.wifi-hb wlan0: Del key for vif(0), key index : 2
Fri Oct 25 03:31:18 2024 kern.info kernel: [10736.253531] hb-fmac 17800000.wifi-hb wlan0: Del key for vif(0), key index : 3
Fri Oct 25 03:31:18 2024 daemon.err hostapd: Using interface wlan0 with hwaddr 94:83:c4:3e:f9:ee and ssid "GL-SFT1200-9eb-5G"
Fri Oct 25 03:31:18 2024 daemon.notice hostapd: WPS: Converting push_button to virtual_push_button for WPS 2.0 compliance
Fri Oct 25 03:31:18 2024 kern.warn kernel: [10736.465486] lmac[1] {CTXT-0} Create channel context: freq=5200MHz bw=80MHz pwr=23dBm
Fri Oct 25 03:31:18 2024 kern.warn kernel: [10736.473325] lmac[1] {CTXT-0} link to {VIF-0}: status=0 nb_vif=0
Fri Oct 25 03:31:18 2024 kern.info kernel: [10736.473581] hb-fmac 17800000.wifi-hb wlan0: AP started: ch=0, bcmc_idx=64
Fri Oct 25 03:31:18 2024 kern.info kernel: [10736.486845] br-lan: port 3(wlan0) entered blocking state
Fri Oct 25 03:31:18 2024 kern.info kernel: [10736.492282] br-lan: port 3(wlan0) entered forwarding state
Fri Oct 25 03:31:18 2024 daemon.notice hostapd: wlan0: interface state HT_SCAN->ENABLED
Fri Oct 25 03:31:18 2024 daemon.notice hostapd: wlan0: AP-ENABLED
Fri Oct 25 03:31:18 2024 kern.info kernel: [10736.500549] hb-fmac 17800000.wifi-hb wlan0: Add key for vif(0), key index : 1
Fri Oct 25 03:31:18 2024 daemon.notice netifd: Network device 'wlan0' link is up
Fri Oct 25 03:31:18 2024 daemon.notice hostapd: 20/40 MHz operation not permitted on channel pri=1 sec=5 based on overlapping BSSes
Fri Oct 25 03:31:18 2024 daemon.warn hostapd: wlan1: Could not connect to kernel driver
Fri Oct 25 03:31:18 2024 kern.info kernel: [10736.859363] lb-fmac 11000000.wifi-lb wlan1: Del key for vif(0), key index : 0
Fri Oct 25 03:31:18 2024 kern.info kernel: [10736.869528] lb-fmac 11000000.wifi-lb wlan1: Del key for vif(0), key index : 1
Fri Oct 25 03:31:18 2024 kern.info kernel: [10736.877666] lb-fmac 11000000.wifi-lb wlan1: Del key for vif(0), key index : 2
Fri Oct 25 03:31:18 2024 kern.info kernel: [10736.885738] lb-fmac 11000000.wifi-lb wlan1: Del key for vif(0), key index : 3
Fri Oct 25 03:31:18 2024 daemon.err hostapd: Using interface wlan1 with hwaddr 94:83:c4:3e:f9:ed and ssid "GL-SFT1200-9eb"
Fri Oct 25 03:31:19 2024 daemon.notice hostapd: WPS: Converting push_button to virtual_push_button for WPS 2.0 compliance
Fri Oct 25 03:31:19 2024 kern.warn kernel: [10737.125685] lmac[0] {CTXT-0} Create channel context: freq=2412MHz bw=20MHz pwr=30dBm
Fri Oct 25 03:31:19 2024 kern.warn kernel: [10737.133537] lmac[0] {CTXT-0} link to {VIF-0}: status=0 nb_vif=0
Fri Oct 25 03:31:19 2024 kern.info kernel: [10737.133864] lb-fmac 11000000.wifi-lb wlan1: AP started: ch=0, bcmc_idx=64
Fri Oct 25 03:31:19 2024 kern.info kernel: [10737.147135] br-lan: port 2(wlan1) entered blocking state
Fri Oct 25 03:31:19 2024 kern.info kernel: [10737.152540] br-lan: port 2(wlan1) entered forwarding state
Fri Oct 25 03:31:19 2024 kern.info kernel: [10737.160784] lb-fmac 11000000.wifi-lb wlan1: Add key for vif(0), key index : 1
Fri Oct 25 03:31:19 2024 daemon.notice hostapd: wlan1: interface state HT_SCAN->ENABLED
Fri Oct 25 03:31:19 2024 daemon.notice hostapd: wlan1: AP-ENABLED
Fri Oct 25 03:31:19 2024 daemon.notice netifd: Network device 'wlan1' link is up
Fri Oct 25 03:31:20 2024 daemon.info hostapd: wlan0: STA c8:58:c0:e6:da:e8 IEEE 802.11: authenticated
Fri Oct 25 03:31:20 2024 kern.warn kernel: [10738.022003] lmac[1] rc_init: station_id=0 format_mod=4 pre_type=0 short_gi=1 max_bw=2
Fri Oct 25 03:31:20 2024 kern.warn kernel: [10738.030003] lmac[1] rc_init: nss_max=1 mcs_max=9 r_idx_min=12 r_idx_max=12 no_samples=10
Fri Oct 25 03:31:20 2024 kern.warn kernel: [10738.038608] add sta(c8:58:c0:e6:da:e8) to hash table 230!
Fri Oct 25 03:31:20 2024 kern.info kernel: [10738.044344] hb-fmac 17800000.wifi-hb wlan0: Add sta 0 (c8:58:c0:e6:da:e8) flags=[SHORT_PREAMBLE][WME][AUTHENTICATED][ASSOCIATED]
Fri Oct 25 03:31:20 2024 daemon.info hostapd: wlan0: STA c8:58:c0:e6:da:e8 IEEE 802.11: associated (aid 1)
Fri Oct 25 03:31:20 2024 kern.info kernel: [10738.058048] hb-fmac 17800000.wifi-hb wlan0: Del key for sta 0 (c8:58:c0:e6:da:e8)
Fri Oct 25 03:31:20 2024 kern.info kernel: [10738.066771] hb-fmac 17800000.wifi-hb wlan0: Del key for sta 0 (c8:58:c0:e6:da:e8)
Fri Oct 25 03:31:20 2024 kern.info kernel: [10738.075017] hb-fmac 17800000.wifi-hb wlan0: Del key for sta 0 (c8:58:c0:e6:da:e8)
Fri Oct 25 03:31:20 2024 kern.info kernel: [10738.084825] hb-fmac 17800000.wifi-hb wlan0: Add key for vif(0), key index : 1
Fri Oct 25 03:31:20 2024 daemon.notice hostapd: wlan0: AP-STA-CONNECTED c8:58:c0:e6:da:e8
Fri Oct 25 03:31:20 2024 daemon.info hostapd: wlan0: STA c8:58:c0:e6:da:e8 RADIUS: starting accounting session 1A2081C3C75863AD
Fri Oct 25 03:31:20 2024 daemon.info dnsmasq-dhcp[2112]: DHCPREQUEST(br-lan) 192.168.2.158 c8:58:c0:e6:da:e8
Fri Oct 25 03:31:20 2024 daemon.info dnsmasq-dhcp[2112]: DHCPACK(br-lan) 192.168.2.158 c8:58:c0:e6:da:e8 DESKTOP-J6PRVGS
Fri Oct 25 03:31:20 2024 daemon.info hostapd: wlan0: STA c8:58:c0:e6:da:e8 WPA: pairwise key handshake completed (RSN)
Fri Oct 25 03:31:20 2024 kern.info kernel: [10738.098789] hb-fmac 17800000.wifi-hb wlan0: Add key for sta 0 (c8:58:c0:e6:da:e8)
Fri Oct 25 03:31:22 2024 authpriv.info dropbear[8492]: Child connection from 192.168.2.158:55458
Fri Oct 25 03:31:22 2024 authpriv.notice dropbear[8492]: Password auth succeeded for 'root' from 192.168.2.158:55458
Fri Oct 25 03:31:27 2024 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED c8:58:c0:e6:da:e8
Fri Oct 25 03:31:27 2024 kern.warn kernel: [10745.153892] rx pkt(1) deauth from [c8:58:c0:e6:da:e8] reasoncode: 1
Fri Oct 25 03:31:27 2024 kern.info kernel: [10745.161327] hb-fmac 17800000.wifi-hb wlan0: Del key for sta 0 (c8:58:c0:e6:da:e8)
Fri Oct 25 03:31:27 2024 kern.info kernel: [10745.169824] hb-fmac 17800000.wifi-hb wlan0: Del key for sta 0 (c8:58:c0:e6:da:e8)
Fri Oct 25 03:31:27 2024 kern.info kernel: [10745.178458] hb-fmac 17800000.wifi-hb wlan0: Del key for sta 0 (c8:58:c0:e6:da:e8)
Fri Oct 25 03:31:27 2024 kern.info kernel: [10745.186492] hb-fmac 17800000.wifi-hb wlan0: Del sta 0 (c8:58:c0:e6:da:e8)
Fri Oct 25 03:31:27 2024 kern.warn kernel: [10745.193579] remove STA c8:58:c0:e6:da:e8 from hash table success
Fri Oct 25 03:31:27 2024 daemon.info hostapd: wlan0: STA c8:58:c0:e6:da:e8 IEEE 802.11: authenticated
Fri Oct 25 03:31:27 2024 kern.warn kernel: [10745.357057] lmac[1] rc_init: station_id=1 format_mod=4 pre_type=0 short_gi=1 max_bw=2
Fri Oct 25 03:31:27 2024 kern.warn kernel: [10745.365046] lmac[1] rc_init: nss_max=1 mcs_max=9 r_idx_min=12 r_idx_max=12 no_samples=10
Fri Oct 25 03:31:27 2024 kern.warn kernel: [10745.373345] add sta(c8:58:c0:e6:da:e8) to hash table 230!
Fri Oct 25 03:31:27 2024 kern.info kernel: [10745.378909] hb-fmac 17800000.wifi-hb wlan0: Add sta 1 (c8:58:c0:e6:da:e8) flags=[SHORT_PREAMBLE][WME][AUTHENTICATED][ASSOCIATED]
Fri Oct 25 03:31:27 2024 daemon.info hostapd: wlan0: STA c8:58:c0:e6:da:e8 IEEE 802.11: associated (aid 1)
Fri Oct 25 03:31:27 2024 kern.info kernel: [10745.392503] hb-fmac 17800000.wifi-hb wlan0: Del key for sta 1 (c8:58:c0:e6:da:e8)
Fri Oct 25 03:31:27 2024 kern.info kernel: [10745.401252] hb-fmac 17800000.wifi-hb wlan0: Del key for sta 1 (c8:58:c0:e6:da:e8)
Fri Oct 25 03:31:27 2024 kern.info kernel: [10745.409607] hb-fmac 17800000.wifi-hb wlan0: Del key for sta 1 (c8:58:c0:e6:da:e8)
Fri Oct 25 03:31:27 2024 daemon.notice hostapd: wlan0: AP-STA-CONNECTED c8:58:c0:e6:da:e8
Fri Oct 25 03:31:27 2024 kern.info kernel: [10745.424830] hb-fmac 17800000.wifi-hb wlan0: Add key for sta 1 (c8:58:c0:e6:da:e8)
Fri Oct 25 03:31:27 2024 daemon.info hostapd: wlan0: STA c8:58:c0:e6:da:e8 RADIUS: starting accounting session 83B7F16D549A4BFC
Fri Oct 25 03:31:27 2024 daemon.info hostapd: wlan0: STA c8:58:c0:e6:da:e8 WPA: pairwise key handshake completed (RSN)
Fri Oct 25 03:31:27 2024 daemon.info dnsmasq-dhcp[2112]: DHCPREQUEST(br-lan) 192.168.2.158 c8:58:c0:e6:da:e8
Fri Oct 25 03:31:27 2024 daemon.info dnsmasq-dhcp[2112]: DHCPACK(br-lan) 192.168.2.158 c8:58:c0:e6:da:e8 DESKTOP-J6PRVGS
  1. Probably the WiFi key is incorrect.
  2. Probably the PC hotspot does not allow offer the IP to SFT1200. (DHCP discover from the SFT1200 but not offer back)
I don't think so. My other two gl.inet devices can connect to mobile hotspot very quickly.
Only this one has this problem. I've upgraded firmware to the latest, no change.Tried many settings on laptop, nothing changed. I think this router's firmware must have something that's different.
What other GL router models are?
May I know what the hotspot info about the bandwidth, channel, Wi-Fi Mode(5GHz or 2.4GHz)?
Please try change to the 2.4GHz for the hotspot
Please try copy/clone the MAC from others available GL router to SFT1200 MAC.
GL-AR750S and GL-MT300N. Both connected fine.
I tried clone AR740S's mac addr, didn't work out. It connects to other routers perfectly, just not to windows 10 hotspot.
May I know what the Win10 hotspot info about the bandwidth, channel, Wi-Fi Mode(5GHz or 2.4GHz)?
May I know what is the usage scenarios to require the router repeat to the Win10 hotspot?
Tried both 5ghz and 2.4ghz, neither worked. Changed to another laptop on windows 10, also failed.
It's because laptop connects to high speed ethernet, so I'd like to use that. Also because my cell phone has very bad cell signal.
  1. Why not move the cable (high speed ethernet) to directly connect from laptop to SFT1200?
  2. What the Win10 hotspot info about the security mode, bandwidth, channel, Wi-Fi mode(5GHz or 2.4GHz)?
  3. According to the syslog you post, looks like the SFT1200 has sent the DHCP discover to PC hotspot, but the DHCP offer was not returned from PC hotspot.
Please help us to check the issue:
  1. the laptop captures the hotspot interface (Wireshark)image
  2. the router captures br-lan (tcpdump -i br-lan -w repeater_dhcp.pcap)
  3. the SFT1200 tries to connect the laptop hotspot
  4. share the 2 pcap files with us.
